Need to know what harness I need for my d15b
Old Oct 18, 2011 | 11:26 AM
1991crx16's Avatar
Default Need to know what harness I need for my d15b
I currently have an d15b sohc vtec motor in my car running off of a p28 with an obd0-obd1 conversion harness and a home made, hacked up mess of a "tucked" engine harness. Some of you may had read other threads about my situation about the car not starting. The wiring is a mess. At this point I would like to put the wiring back to as normal as I possibly can. I'm not sure if I need the engine harness for the car or for the motor or anything else I may need. I've searched on here and I know it cannot be exactly original since it is not the same motor but could someone please help me out?
Old Oct 18, 2011 | 01:50 PM
v4lu3s's Avatar
RTFM
Default Re: Need to know what harness I need for my d15b
it will be easiest to get the engine harness that matches the chassis harness, so if for example you had a crx si and the chassis harness was still original you could use an si engine harness.
Landman93
Feb 1, 2016 01:30 PM
bradennicely
Apr 25, 2010 04:36 PM
CRX_Honda
Nov 14, 2008 05:06 PM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
