water pump question
Old Oct 17, 2011 | 10:32 PM
Built4Battle's Avatar
Default water pump question
can i use a ls water pump on a b16?
if so do i use the ls timing belt?
also will this be reliable for boost?
or should i just go with b16 water pump?
thanks
Old Oct 18, 2011 | 05:42 AM
kyden's Avatar
Default Re: water pump question
you cannot use an ls belt on a b16 (too long). get the right pump.
Old Oct 20, 2011 | 12:11 PM
Markyboy's Avatar
Its a b16 why would you try to use a ls water pump?? Dont be cheap if your going to boost get a type r or a good aftermarket high flow pump like mieser.
Andrewvtec
Jan 21, 2011 12:23 PM
cincyb20ek
May 5, 2010 04:51 PM
soon2bdropped
Jul 22, 2007 11:33 AM
19sec beast
Mar 31, 2006 04:40 AM
built562
May 4, 2003 07:27 PM
