Are the 96-98 and the 99-00 civic ex engine wire harness the same
Old Oct 17, 2011 | 02:11 PM
whyS0serious's Avatar
Default Are the 96-98 and the 99-00 civic ex engine wire harness the same
Are the 96-98 and the 99-00 civic ex engine wire harness the same or are there any different connectors that they have?
thanks in advance
Old Oct 17, 2011 | 03:14 PM
BAM! 93 hatch's Avatar
Default Re: 96-98 99-00 ex engine harness
96-98 is obd2a 99-00 is obd2b no major difference but there is.
Old Oct 17, 2011 | 03:15 PM
I believe the difference is in the ecu connector.
Old Oct 17, 2011 | 05:33 PM
bpl0807's Avatar
Exactly what the guy above me said, the connector is the only difference between the two.
Old Oct 18, 2011 | 05:38 AM
kyden's Avatar
actually the distributor connector is different too.
Old Oct 18, 2011 | 05:55 AM
m3tech95's Avatar
Correct....
Old Oct 23, 2011 | 08:22 PM
how about the engine harness for the 99-00 ex and 99-00 si?
Old Oct 23, 2011 | 08:49 PM
twotonecivic's Avatar
Default Re: Are the 96-98 and the 99-00 civic ex engine wire harness the same
i believe ex and si are different
Old Oct 24, 2011 | 06:08 AM
kyden's Avatar
they are different, ex has an 8 pin rectangle connector, the si has a square 10 pin.
Old Oct 24, 2011 | 09:16 AM
Thanks for the quick response guys appreciate it
Old Jan 12, 2015 | 08:28 AM
98EK_HB's Avatar
Can I swap the dizzy internals from the obd2b dizzy to the obd2a dizzy?
Old Jan 12, 2015 | 04:51 PM
HondaPartsHero's Avatar
Technical Hero
Yes
Old Jan 12, 2015 | 05:22 PM
NotARaCist's Avatar
I never narc'd on nobody!
For the 3 people who said that the engine harness was the same, go ahead and try swapping a 96-98 harness into a 99-00. Go ahead. I'll wait.
They aren't the same. You can't mix and match.
Old Jan 12, 2015 | 06:20 PM
Former User's Avatar
Old thread closed.
stokeless1
Jul 9, 2008 05:39 PM
alacard
Jun 16, 2007 10:53 AM
xsuperxsonx
Jul 25, 2006 08:09 AM
97_hatch
Jul 6, 2006 09:46 PM
Timmay
Aug 15, 2005 03:59 PM
