HELP!!! Accord with H22
Hi, I have a 94 accord with a 97 H22. My problem is that when I'm driving the speed gauge seems to read higher than what I'm actually traveling. I don't know much about swaps so ur help will be greatly appreciated, thanks.
If you put the F22 transmission in the accord mated to the h22 you will be rocking and rolling.
The VSS for the H22 transmission has more pulses per revolution then the F series transmission. There are electronic devices that allow you to take lets say 100 pulses in and translate that to 80 pulses out.
You might want to look into an adjustable VSS converter for the S2000 gauge cluster swaps in peoples cars.
yeah I dont know what transmission thats for, I just know the electronics of how it all works.. It was the same problem I had which is why I ended up doing a custom dash with autometer gauges so I could calibrate it myself.
hondafreak2134
May 2, 2009 09:57 AM
