90 Civic: Brake question
Old Oct 17, 2011 | 10:03 AM
phirewire's Avatar
Default 90 Civic: Brake question
Just got my car running, its a 90 Honda Civic DX Automatic.
I've been driving a 96 Cavalier with powerbrakes and when driving my car last night, The brakes didn't seem to do anything.
When I was pulling it out of it's spot, when switching gears it hit drive instead of reverse and even with my foot on the brake it jumped forward
Is there anything I can do, is there a way to put on powerbrakes?
Old Oct 17, 2011 | 10:38 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 90 Civic: Brake question
Huh? Which vehicle are you talking about? What exactly do you mean by "power brakes"? Do you mean ABS or just vacuum assist braking? If its the latter, they come with those stock. If you are talking about the Honda - the master cylinders are known to fail.
Old Oct 17, 2011 | 10:55 AM
94eg!'s Avatar
#1 Super Guy
Loved
Your Honda does have power brakes. The booster is the big black circular thing in the engine bay attached to the fire wall (brake fluid reservoir is attached to it).
- If your pedal is going squishy and goes too far down without stopping the car, you either have a fluid leak somewhere or you need a new master cylinder (internal leak past the piston).
- If your pedal is too rock hard for you to push enough to make the car stop, you most likely have a bad brake booster.
- It is also possible, however unlikely, that if someone has worked on the brakes right before this happened you may just need to re-bed the pads. I've seen this once on my friends Civic w/ Autozone pads. Every time we took the pads out and put them back in (in the same place) the brakes almost zero friction whatsoever. They required several hard stops before they would function again.
If your not sure about any of this, don't drive the car.
Old Oct 17, 2011 | 03:19 PM
phirewire's Avatar
Well this was a problem before and we just bleed the breaklines replaced fluids ect, no leaks or air inside. But it still has an issue, Just replaced the engine as well. (Bad pistons)
Old Oct 17, 2011 | 05:47 PM
94eg!'s Avatar
#1 Super Guy
Loved
Is the vacuum hose connected from the booster to the intake manifold?
Is the check valve in that hose working (you should only be able to blow through it one direction)?
Is the check valve installed the right way (air must flow from the booster to the manifold only)?
Chev
14
Oct 20, 2017 03:32 PM
da1lydr1ver
Suspension & Brakes
Mar 28, 2012 06:56 PM
losol
Suspension & Brakes
Jun 2, 2011 07:23 AM
nis240rb
Suspension & Brakes
Jan 13, 2009 02:55 PM
