91 Integra Corner Light Problem (No power to green wire)
Old Oct 16, 2011 | 10:58 PM
EJ1_CRIS_909's Avatar
Default 91 Integra Corner Light Problem (No power to green wire)
Hey everyone, Well like the title states I obviously am having a problem with my corner lights. I have Stanley one pieces and it was ghetto wired from the previous owner but the problem is, the green flasher wire has no power for both sides.
I was attempting to wire up the sidemarkers because they have been off since I bought the car and everything else with solder and shrinkwrap, and I had to wire em to the bumper light instead. But the green flasher wire to the bumper lights works perfectly fine. I honestly have no clue what it could be and I did do some research before posting. All help is appreciated. Thanks
Old Oct 17, 2011 | 06:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: 91 Integra Corner Light Problem (No power to green wire)
Do you mean the green/white, [left] and green/red, [right] leads, [front side markers], there is no just green leads for any of the front lights on your car.
If so, the front side markers are controlled by the ICU, a common problem on older Honda/Acura.
The front side markers should blink ON when signals or hazards are used, they should turn ON when park/head lights are on and blink Off when signal or hazard lights are used if park/head lights are on.
Question, do you intermitant wipers work, does your rear window defog still work, do all your warning chimes, [seat belt, key still in ign., lights still on] still work?
All the above are also controled by the ICU, if any or some/all of the above are not working then it is a good bet your problem is the ICU.
With that said, all the above may still work and the front side markers not. 94
Old Oct 17, 2011 | 10:25 AM
Yes sir, I just didnt wanna go too into detail with the color. The wipers work, the defroster does, and everything beeps when its supposed to, and I already came to the conclusion that my ICM was bad because its been beeping at random times non stop, but I had NO idea it controlled the front sidemarkers.
Thank you fcm for the info, I do greatly appreciate it.
rudyndrew
Dec 10, 2011 11:46 PM
VtecHachi
Feb 12, 2007 01:00 PM
rjr162
Audio / Security / Video
Feb 14, 2005 05:56 PM
Eatvtec97
Apr 21, 2002 04:36 AM
