Negative ground?
Old Oct 16, 2011 | 10:16 PM
540dude's Avatar
Default Negative ground?
Where would be the best/easiest place to connect a negative wire to a ground from the interior?
Old Oct 16, 2011 | 11:10 PM
gstrudler's Avatar
Default Re: Negative ground?
Where in the interior? I've used the seat bracket bolts before with good success for anything under the seats. For anything by the dash, find an existing ground point and add it to it.
Old Oct 17, 2011 | 05:31 AM
540dude's Avatar
Yeah, probably under the dash. Thx!
Old Oct 17, 2011 | 05:38 AM
Hawkze_2.3's Avatar
You can ground to anywhere on the frame of the car, as long as you remove the paint at the point of contact.
Old Oct 17, 2011 | 05:35 PM
AWDManiac's Avatar
just fyi you shouldn't use the seat bolt bracket fir a ground unless you test the resistance (ohms) with a multimeter. Grounds exist all over the car, usually a great place for a ground on any vehicle is in the kick panel (driver side)
I use that area for alarms often, and I just scrape the paint away with a wire brush on my drill. But our cars are a unibody vehicle, which means most areas on the vehicle that are the frame will be a great area. Always test though, some grounds can be a descentbground for low current, but as current increases it gets worse.
Old Oct 18, 2011 | 08:57 AM
540dude's Avatar
Thx guys... I ended up just going through my firewall and using a ground under my hood close to the windshield.
ALDJ253
Mar 11, 2014 03:41 PM
MilanoRedDashR
Audio / Security / Video
15
Jul 3, 2009 05:44 AM
vinuneuro
Aug 30, 2007 01:38 PM
Fatty_1775
Aug 25, 2004 06:57 AM
importfan85
Sep 21, 2002 12:47 PM
