how to hold not magnetic pipe to tack.
Old Oct 16, 2011 | 01:28 PM
b16bri's Avatar
Default how to hold not magnetic pipe to tack.
Hey guys I was wondering what are some tips and tricks of the trade to hold aluminum and SS pipes/ plates in place long enough to tack them together considering magnets wont work on eaither metal. T-joints, IC piping ,manifolds, Down Pipes, ect what meathods have you guys tryed and find to work.
Old Oct 16, 2011 | 02:33 PM
intense4thgen's Avatar
Default Re: how to hold not magnetic pipe to tack.
I use a small strip of tape to hold the ends flush while I tack also sometime I'll toss it in the vice depending on the part
Old Oct 16, 2011 | 03:27 PM
atutt's Avatar
My left hand. Since I'm a righty..
Bessy clamps, modded c-clamps, vise, vise grips, hose clamps, tape, etc...
Get creative. Or buy pipe clamps.
Old Oct 16, 2011 | 03:50 PM
b16bri's Avatar
Cool keep them comming guys ? Any one have any pics of there modded/creative clamps
Old Oct 16, 2011 | 03:55 PM
frostyrb's Avatar
i use those v block clamps that machinist use also.
Old Oct 16, 2011 | 04:12 PM
b16bri's Avatar
im not familiar with thoes clamps ?
Old Oct 16, 2011 | 04:41 PM
turbojdmhatch's Avatar
use your off hand.
Old Oct 16, 2011 | 09:18 PM
PTPbracket's Avatar
Good fitment so a fusion tack is possible. Then burn your fingertips.
Old Oct 17, 2011 | 12:00 AM
jere's Avatar
Aside from the previously mentioned, I like to tack scrap metal to my welding table to keep pipe in place, kind of a half arsed jig.
Old Oct 17, 2011 | 05:16 AM
b16bri's Avatar
Thanks guys for all the great info keep them comming people, pics are always welcomed. As for the fusion welds i have no problem when it's mild steel but when I was trying to do aluminum I wasemt having much success with a fusion tack. Probually due to bad fit up but any tips on that.
Old Oct 18, 2011 | 08:01 AM
weiRtech's Avatar
OG Fabricator
put it in a vise.
Old Oct 26, 2011 | 11:55 PM
Boosted_B_Series's Avatar
Pipe clamps work wonders,
I got two sets off ebay through summit, adjustable 1.5-3" I believe.
I use them all the time, even to hold pipes in funny angles in the chop saw.
Old Oct 27, 2011 | 07:18 AM
that-guy's Avatar
i typically use welding tape...its super sticky and strong, so it will hold even with the weight. cut three pieces to wrap all the way around the pipe, allowing about an inch between each piece to place your tack. then remove the tape, use acetone to clean the adhesive off the surface, and do your final welds
Old Oct 27, 2011 | 12:12 PM
SovXietday's Avatar
You need perfect fit (it helps to push the two joints together) and a lot of heat really fast across the joint to tack aluminum. Just takes practice.
You can also weld a small ball onto the edge and then use the small ball to tack over to the piece of metal you're trying to weld it to, I usually use this method when I'm welding in bungs where getting perfect fit is much more difficult, and the ***** also help hold it in place while I tack it in.
Old Oct 28, 2011 | 04:54 AM
D-Rob's Avatar
I agree with the fitment bit. Make your joints fit well, and tack without filler.
I do everything like this - AL, SS, etc..
Old Oct 28, 2011 | 01:50 PM
b16bri's Avatar
So to do this correctly with out filler. Do i turn the heat up higher than i would if i was actually wedling ? And do I just hit the pedal real hard and let off or do I need to hold the pedal down for a bit.
Old Oct 28, 2011 | 02:42 PM
91jdmhatchback's Avatar
Hold the parts with your free hand unless there excessively heavy. for tacking you should never need more amperage then your using for welding that particular material. Just strike an arc and give it a swift pump of the peddle if not using pulse. Or if pulsing a few pulses gets the job done.
I have never got to into the clamps and tape, makes tacking WAY to inefficient. But my fitment is always very tight fitting. I never exceed the material thickness in gaps. The finished product shows poor fit up.
Old Mar 8, 2015 | 05:07 AM
Tjabo's Avatar
You wouldn't happen to have any pics of these handy would you?
Old Mar 8, 2015 | 12:10 PM
turbohatch96y7's Avatar
I hold the pipe with one hand and tack with the other
Agree fitment has to be tight. Cant be a gap or youll never tack it
16 gauge pipe i use 25 amps
Urinemachine
Welding / Fabrication
14
Apr 27, 2012 04:41 PM
jdmcivic2fast
Feb 14, 2011 01:37 PM
Superorb
16
Feb 23, 2006 06:18 PM
BlueShadow
Jun 11, 2005 09:32 PM
SRd240sx
Jan 10, 2005 12:00 AM
