flashing "S" light.
Old Oct 16, 2011 | 11:54 AM
fringledingle's Avatar
Icon6 flashing "S" light.
Greetings,
I just picked up a '90 accord ex. The "s" light starts flashing when I shift into gear. I just replaced the VSS. Alas it did not remedy the problem. Do I need reset the TSU somehow or does it mean the VSS I got from the wreckers is buggered too?
Thx
Old Oct 16, 2011 | 01:01 PM
jdmcertified909's Avatar
Default Re: flashing "S" light.
Originally Posted by fringledingle
Greetings,
Thx
How do you know its the vss? Have you pulled the codes from the tranny ecu
Old Oct 16, 2011 | 01:19 PM
P_Adams's Avatar
Greetings,
Thx
There was a manufacturing issue (quality control) on the TCU's installed on this generation Honda's which cause this complaint. The Capacitors utilized tend to fail. This can be confirmed by inspecting the motherboard's can capacitors and look for leakage. If you should fall prey of this malady, nothing short of replacing the TCU will do. :-(
P
Old Oct 16, 2011 | 01:24 PM
P
Or simple solenoid happened two me TWICE ON TWO ACCORDS I OWN
Dalang
Sep 25, 2008 07:21 AM
b00sted4dr
Dec 21, 2006 10:31 PM
Hondafreak2006
Sep 17, 2006 07:33 PM
hydeehydee
Sep 5, 2005 09:23 AM
