will this work in b18c??
I wouldn't purchase that kit personally though. Stock/oem crank is the best choice.
As long as you match your crank to your rods it's fine for height. Pistons decide your compression nothing else. You can mill the head and/or block and get a little more compression but not much. Also flat faced valves can bump compression or a different head gasket. These things don't play a very big role though. Might be able to jump a 9:8:1 to 10:0:1/10:1:1 The ls has a longer stroke then a gsr that's why they always produce higher torque. This combo gives you the stroke of an Ls motor with the strength of a gsr motor in one.
Crank, rods and pistons all determine compression.
LS crank and pistons with b16 rods will have less compression, likewise ls rods+pistons on a b16 crank will produce lower compression. All of these are important.
You cant say that destroking a car will keep the compression the same
Anyways Op, play around with this compression calculator to find out the range you want to be in.
http://www.zealautowerks.com/
integranator
May 12, 2006 02:56 AM
Chugger
Mar 3, 2006 01:22 PM
