98 Civic EX Rear Disk Swap with ABS....Pedal Feels Soft???
I have a 98 civic 4dr EX with abs and just completed a rear disk swap. I used rear trailing arms, calipers etc from a 2000 integra with abs and a prop valve from a 98 integra gsr & a 00 civic si with the 2 extra ports plugged. I've tried both valves with the same result. After bleeding the pedal feels soft (bleed correctly and in the right order), it still catches but doesn't feel as solid as the drum brakes. THERE ARE NO LEAKS. (I know someone will ask) Any ideas why I'm getting a soft pedal feel?
I highly doubt some very fine dirt would make the master cylinder fail & master worked fine before the swap..thanks for the reply though
When I installed new brake hoses on my Integra, I had to bleed them about 5 times over the course of a month before the pedal was firm. I would see a small amount of air each time. I also took care to plug the hard lines when the hoses were removed to minimize air infiltration.
just trying to clear something up.. Your 98 ex came with abs right? And the swap is an abs model correct? Did you use the prop valve off a teg that had abs. Pretty sure the abs props and non abs props are completly different ?? Just a suggestion.
Yes my car came from the factory with abs. I'm also using a swap from a 2000 integra with abs. I'm also use a prop valve from and abs integra that i bought new from acura. I've also used a prob valve from a 2000 si with the 2 extra ports plugged with the same spongy feeling.
this is more than likely exactly why your pedal feels shitty. when you lose fluid in the master and pump the pedal, you push the piston past where is ever goes. then the seal gets damaged by the dirt in the cylinder. happens all the time.
But it still grabs and stops pretty well once you press the pedal hard enough, it just feels spongy at first. Would a failed master still actually stop the car?
i would bleed at the master cylinder as 96electronH said. crack the nut loose putting a rag over the nut to prevent it from spraying. Then put a large rag below to catch the fluid(brake fluid eats paint quickly ) and have them hold the pedal down and tighten it up. repeat that on both brake lines on the master cylinder. then do all 4 starting with RL,RR,FL,FR. do that before going off and buying a new master cylinder
FabianAra
Jan 30, 2018 08:02 PM
sinyce
Aug 2, 2016 10:48 AM
PhrequenC
Jan 8, 2012 04:10 PM
