Are main studs the same as head studs?
Old Oct 15, 2011 | 09:47 PM
Cap'N Chronic's Avatar
Default Are main studs the same as head studs?
So I blew a head gasket and I'm going to buy some ARP headstuds. I found a set of ARP main studs on Summit Racing, and I'm wondering if main studs are the same thing as head studs?
Old Oct 15, 2011 | 09:51 PM
speedooo's Avatar
Default Re: Are main studs the same as head studs?
No...main studs are part of the bottom end
Old Oct 15, 2011 | 10:43 PM
Linked's Avatar
what exactly are main studs?
Old Oct 15, 2011 | 11:04 PM
marshun's Avatar
this isnt really the type of question you ask on a board. but theyre the studs that hold the main bearings.
Old Oct 15, 2011 | 11:31 PM
Linked's Avatar
i didn't know there studs instead of bolts for the mains in our engines :S
Old Oct 16, 2011 | 06:12 AM
92lxsleeper's Avatar
there is. honda uses bolts factory, but you can change out to studs if you want. better idea especially if you want a higher revving bottom end. helps prevent crank walk too.
Old Oct 16, 2011 | 06:47 AM
Turpid Porpoise's Avatar
i think its cute that linked has one of your quotes in his sig
gooblinn258
Apr 21, 2014 05:21 AM
bigbpatel
Nov 9, 2012 04:38 PM
kornerk12
Feb 7, 2007 09:03 PM
d16dcoe45
Oct 27, 2006 03:19 PM
s2kkid
Dec 12, 2004 05:42 PM
