Distributor problem, car wont crank now.
Old Oct 15, 2011 | 08:41 PM
xOtakuBuster's Avatar
Default Distributor problem, car wont crank now.
I took my distributor off yesterday to replace the o ring, I made sure everything was still lined up when I took it off and I ran to the parts store, so I get back and the endlink on the dizzy has been spun. I tried to line it up and put the dizzy back on but all it does it turn over it wont crank, im guessing I need to adjust my ignition timing? and if so how do I do it? thanks
Old Oct 15, 2011 | 11:52 PM
motegicivic's Avatar
Default Re: Distributor problem, car wont crank now.
So you marked it before taking it off?
It is keyed one way, take it off and spin it 180 degrees and try again.
Also, did you remove the wires? if so check the firing order.
Old Oct 16, 2011 | 08:41 AM
tui's Avatar
tui
The distributer will only fit in one way, you cannot make a mistake with this.
What excatly do you mean when you say turn over and won't crank. Turning over is cranking.
Need more info please.
Mikeedubb
Oct 11, 2012 06:00 PM
NickTJohnson
Feb 21, 2008 08:50 AM
erikiksaz1
Dec 25, 2004 06:25 PM
