Lighting HID/Xenon kits, Retrofits and Associated Topics
having trouble with wireing up retor fit to a 97 civic need help
Old Oct 15, 2011 | 05:44 PM
CHAMPwhteEK's Avatar
Default having trouble with wireing up retor fit to a 97 civic need help
so i have 99 civic headlights with S2k projectors... when wiring up the headlights i get no power. but when i take off the cover to the relay and touch the plate to the other plate i get power.... everything is grounded and the pre wirring for the kit was done by a honda tech member...im thinking something to do with the harness for the car its self... any ideas??? also i made sure it wasnt a bad relay and replaced it and that didnt work also
Old Oct 17, 2011 | 07:31 AM
Joon Joon's Avatar
Default Re: having trouble with wireing up retor fit to a 97 civic need help
you got pics of how everything is wired up?
Old Oct 18, 2011 | 11:39 AM
PICS of harness
Old Oct 18, 2011 | 01:39 PM
Joon Joon's Avatar
wow theres too many fuse holders.. have you checked the fuses?? everything grounded well?
Old Oct 18, 2011 | 05:54 PM
yeah checked every fuse and everything is correctly grounded
Old Oct 18, 2011 | 06:59 PM
Joon Joon's Avatar
can you take a pic of the input connector
Old Oct 18, 2011 | 08:49 PM
im sorry but what would that be exactly
Old Oct 18, 2011 | 09:26 PM
Joon Joon's Avatar
the connector that plugs into your stock h4 connector.. forgot to ask, you have the 9006 connector going to the ballast the right way?
Old Oct 20, 2011 | 05:56 PM
the right way...what would be the wrong way?..lol
Old Oct 20, 2011 | 09:05 PM
Joon Joon's Avatar
the connector could go either way thats why im asking which you put it..
Old Oct 24, 2011 | 05:27 PM
yes i do have that pluged in the right way
Old Oct 25, 2011 | 05:41 AM
Joon Joon's Avatar
thats why i asked for pics of the input connector... for h4 systems, theres positive and negative grounded circuits.. so you might have to move pins around..
Old Oct 25, 2011 | 08:04 PM
will check tomorrow after work..then will post more info...
Old Oct 25, 2011 | 08:09 PM
ill also get a picture of my car harness because it was butchered a little bit by the previous owner
LSeeper
Dec 23, 2004 12:34 AM
dankris
Jan 19, 2004 09:40 AM
dowhatyouwant
Sep 23, 2003 09:47 PM
TypeR 508
Apr 22, 2002 09:44 AM
