Is new transmission cooler needed
When I swap the transmission on my 1997 Accord will I need to put a new cooler on it or will it be OK to hook it to the old one? Also what all am I going to need to replace as I am getting a transmission off of a wrecked 97 Accord to replace it.
B4 you install the "New to You" transmission; I would suggest that you have the external seals replaced b4 you install it.
Torque Converter seal
Axle seals
etc.
You don't want to have to pull this thing back out 5 months from now because something started messing itself :-)
P
Good luck on that Derrick ! *
Take your time and keep things clean :-)
P
*oh, take notes too if this is your first. It makes it easier going back in ;-)
P
1999 honda Accord Cali
Jun 8, 2008 08:36 PM
