Where to find tsx projector?
Hey guys, I am looking to find tsx projectors somewhere, but so far I've only found the shrouds. Can anyone put links up or give me an idea where to find them?
I do not want to buy ebay ones, and I also wanted to know what bulbs I need for the tsx ? I think they are H1's?
thanks guys I want to do a retrofit
ya actually I ending up finding a post about retrofitsource.com and found the wiring kit and the other piece I needed. I found the write up on the a4 retrofit which is what I will do instead. Thanks
Skip the A4. There are better options out there. I have the Morimoto Mini H1 kit from TRS and I'm very happy with the results. For example: the cutoff, width of output, and quality of parts is exceptional considering the cost of the parts and there is NO NEED to hack up your headlights to retrofit them. If you have OEM headlights get the standard Mini H1 kit, if you have JDM headlights get the D2S Mini kit. You will not be disappointed.
. used a belt sander to modify the e46 shrouds. dont forget to make a shield to block light from escaping the projector. i used some leftover exhaust wrap(painted flat black with high temp paint on one side to prevent replections) and jb weld putty to seal the projector
nitro911
Jul 30, 2012 05:38 PM
Getting a hid kit soon but want projector headlights for a eg? where can I find some and what are th
Markb16a
Dec 6, 2006 06:26 PM
