need help: 99 civic with P0505
Old Oct 15, 2011 | 11:06 AM
blk crx's Avatar
Default need help: 99 civic with P0505
Have a 99 civic ex 5 speed.
Replaced the iac 5 times with 3 used and 2 new.
And the cel keeps popping up for iac.
I can drive all day with no issues.turn the car off .then drive it again until I come
to a stoplight ot stop sign.then light comes on and it stars idling bad.
If anyone has any ideas please help
Old Oct 20, 2011 | 06:28 AM
blk crx's Avatar
Default Re: need help:civic keeps eating idle air control valves
swapped out the ecu and still doing the same thing
Old Oct 20, 2011 | 06:52 AM
b16a2ek's Avatar
check for vacuum leaks on the intake manifold and hoses
Old Oct 20, 2011 | 07:03 AM
techtalk's Avatar
blk crx,
Inspect the Vacuum bulk hose for any vacuum leaks. It's shown as ref # 14 in the diagram below:
*diagram courtesy of hondapartsnow.com; all rights reserved
Old Oct 20, 2011 | 10:49 AM
owneyboy's Avatar
check map sensor/tps/fitv
Old Oct 20, 2011 | 12:04 PM
Supaslowsi's Avatar
my 2000 si does this too, but when i try to take off from a light and push the gas a little the motor starts pulsing from about 1600-1800. any ideas of what this could be?
Old Oct 20, 2011 | 05:26 PM
Steezer's Avatar
Intake manifold gasket or vacuum leak in hose 14 in the diagram above
Old Oct 30, 2011 | 11:34 AM
blk crx's Avatar
Another question.why do you guys think its #14 that's leaking?
Old Oct 30, 2011 | 11:36 AM
blk crx's Avatar
Mine does it also
Old Oct 30, 2011 | 11:53 AM
mystereo's Avatar
Did you bleed the cooling system for air bubbles? Jump the ECU with a paper clip and see if there are any other codes besides the one for the IAC.
BTW, I'm not sure what the possibility of getting that many problematic IACVs but I know it's possible. I bought one that was defective and once I got one that actually worked, my idling issue went away.
Old Oct 31, 2011 | 07:08 AM
Supaslowsi's Avatar
Car stopped all issues on its own now runs great and didn't really do anything but scratch my head in confusion... Weird
Old Oct 31, 2011 | 09:44 AM
Former User's Avatar
If the problem pops up again, pull the code with an OBD2 code reader and post it. The problem obviously wasn't a bad IACV.
Old Oct 31, 2011 | 10:23 AM
jdmcertified909's Avatar
a thread like that was just solved. could help you. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1997-civic-si-jerky-throttle-iacv-cel-2993155/
Old Nov 1, 2011 | 07:46 AM
blk crx's Avatar
Originally Posted by jdmcertified909
a thread like that was just solved. could help you. https://honda-tech.com/forums/showthread.php?t=2993155
thanks for the link but.i've tried everything it said.i have cleared the code like 20 times this month.but i found out if i pull the backup fuse i can go longer with out the cel popping on.
and as far as the code it shows twice on a scanner. a p0505
Old Nov 1, 2011 | 10:29 AM
Default Re: need help: 99 civic with P0505
Why would you wait this long to post the CEL code in this thread - title edited.
You also have not yet described the idle problem. Is it high, low, and/or surging?
Old Nov 2, 2011 | 01:49 PM
blk crx's Avatar
sorry about that.
it idles at 1500 and when you give it gas on take off it starts kicking and bucking.also when you let off the gas.
Old Aug 15, 2013 | 06:28 PM
omerfar23's Avatar
sorry about that.
I have the same exact issue, can you please share resolution or any updates with us?
Old Oct 29, 2013 | 06:11 AM
DeLSoLRo's Avatar
Ive been dealing with this issue for months now. Ive replaced the part and still get this issue. Clear the code using a scanner, 1-2 days later it comes back up. P0505 and sometimes twice (pending). Car jerks a little when i engage the clutch, if i cruise in neutral the idle will surge from 1k-2k until the car stops. If i press the gas pedal slightly and hold it will surge pretty fast from 1k-2k. Sometimes I will get a P0420 and P0310 but thats likely due to my ebay 02 sensor readings from my exhaust. (yonaka hi flow cat. converter+cat back system exhaust). I have gotten codes P0420 and P0310 and car runs normal. Only when I get P0505 does the car jerk.
I found this site that tells you how to diagnose it, I will attempt this tonight and see how it goes.
http://www.obd-codes.com/p0505
I have yet to swap out the ECU.
sumocivic
Aug 3, 2010 11:31 AM
SonyaE
Mar 28, 2009 07:47 PM
Import_spoon
Nov 20, 2007 11:10 PM
JSPECHB
Mar 27, 2004 07:17 PM
