1996 Honda Accord - press gas, idle speed drops, car chokes and dies
Old Oct 15, 2011 | 06:51 AM
goretoya's Avatar
Default 1996 Honda Accord - press gas, idle speed drops, car chokes and dies
Alright i am a new member and desperate for some help to my problem. I have 96 accord automatic. Car runs perfectly fine when parked and ideling. As soon as the car warms up and you press the gas, the rpm drops to the point where the car chokes and sometimes it will shut off completely.
The timing belt is new, throttle position sensor is new, i cleaned the idle control valve. I do not have a clue as to what it could be. Any help would be greatly appreciated.
Old Oct 15, 2011 | 01:17 PM
P_Adams's Avatar
Default Re: 1996 Honda Accord - press gas, idle speed drops, car chokes and dies
I would have a scanner hooked up to the data port and specifically watch the voltage from the Primary O2 sensor.
I had a customer's car which ran absolutely GREAT when first started; but within 2.5 to 4.0 minutes of running would stop responding to throttle inputs, would run 'flat' and almost backfire out the TB and would require pulling over. The surprising and more than a little aggravating was the fact that after 2 minutes or so - it would clear up and run great until (again) we started up from ambient temps ... and off to the races we would go again.
What was happening was this: As the O2 sensor heated up, it developed an intermittant short between the power feed side to the signal side of the sensor. This (in effect) fed an unusually high voltage back to the computer (which interpreted this as a super-rich condition at the exhaust). Being the Good computer it was, it commander the injectors to lean WAY out - thus the flat spot and no power. As the O2 sensor continued to heat up, the internal short corrected and the sensor operated normally.
The computer didn't set a code because the voltages were present / uninterupted - just out-of-range.
have the Primary O2 sensor checked.
P
Last edited by P_Adams; Oct 15, 2011 at 01:18 PM. Reason: stupid spelling error :-(
EVS90
Mar 22, 2014 03:42 PM
rodbuster00
Jul 11, 2013 11:44 AM
CBL9
Mar 24, 2012 05:33 PM
xilef1025
Jan 10, 2012 07:40 AM
russ2169
Oct 23, 2009 03:22 AM
