honda accord 1992
Old Oct 14, 2011 | 08:55 PM
davidalarcon12's Avatar
Default honda accord 1992
I have a honda accord 1992 lx and Im having problems with the rpms, once i stop completetly at a light the rpms are going up and down, I have change map sensor but didn´t work, once i disconnect the map sensor the car runs fine but check engine light comes on, please help.
Old Oct 15, 2011 | 01:39 PM
jdmcertified909's Avatar
Default Re: honda accord 1992
Before anyone helps you with anything you need diagnose the cel. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/ go there jump it then come back and post the code (code doesnt tell you what to replace) just tells you where the problem is futher diagnosis is needed to pinpoint exact problem.
Old Oct 15, 2011 | 02:03 PM
P_Adams's Avatar
First, make sure that the cooling system is properly filled. There is a thermally activated Fast Idle valve mounted to the intake manifold which can cause this problem. There can be NO AIR in the coolant system - nothing! If that doesn;t calm things down then (Yes!) determine what the ECM is saying to you via the CEL Lamp. Although I've caught them lying (from time to time) Honda computers are preety good at self-diagnosing the system.....
P
Old Oct 15, 2011 | 07:14 PM
thanks for your help, when i bought the car it was in a yunk yard, they changed the motor and manual transmission, i didn´t notice but a few months back the Fast Idle valve was blocked w. a stick. I will checked out and come back, thanks.
AztecZero
May 7, 2018 09:15 PM
Alfredo1952
Oct 11, 2017 06:49 AM
NoHondaexpert
Jan 2, 2014 09:43 AM
rufus13ky
Sep 22, 2013 11:05 PM
Brum_RU
Dec 14, 2007 12:31 PM
