Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
exhast manifold 2002 civic
Old Oct 14, 2011 | 08:09 PM
hondajdm311's Avatar
Icon2 exhast manifold 2002 civic
I have a 2002 civic lx with a d17 and my exhast manifold cracked... i was wondering if a d16 mani will fit?
Old Oct 14, 2011 | 08:27 PM
It Wasn't Me's Avatar
Default Re: exhast manifold 2002 civic
Not without modification. (more than it's worth)
This has been covered before.
Old Oct 15, 2011 | 01:57 PM
ok
so what your saying is i have to buy a brand new one?
Old Oct 15, 2011 | 03:07 PM
MindBomber's Avatar
That's not what he's saying at all, he simply responded to your question, answering that a d16 manifold will not work. I'm not sure how you derived the idea that you need to purchase a new D17 manifold from that, you can purchase a new or used part, your call.
Old Oct 15, 2011 | 07:23 PM
toyomatt84's Avatar
Sanji
Keep in mind that your exhaust manifold has a catalytic converter within it (EX models have a different style manifold, where the cat. converter is further down the exhaust stream).
Old Oct 20, 2011 | 07:37 PM
sorry i just was talking to a guy at a junk yard and he was saying how with the cat on it they usually wont have them in junk yards... so i was wondering if theres any other manifolds from another motor that will fit? i was trying to see if theres any i can get that will eliminate the cat? cheaper easier fix??
Old Oct 21, 2011 | 06:24 AM
toyomatt84's Avatar
Sanji
You could eliminate the cat., but it will require an EX manifold, midpipe, and downpipe (also known as the "b-pipe"). You could get some of these aftermarket, but the midpipe will either need to be OEM or the whole cat-back exhaust portion will need to be aftermarket. Also, you'll have to extend the wiring for the secondary oxygen sensor, and run either an oxygen sensor spacer, some spark plug defoulers, or an O2 sensor emulator.
Also, given all that work, you're going to still have a really raspy exhaust note (unless you invest in some extra resonators).
Check Rockauto.com for replacement cat.'s and see if they don't have what you're looking for.
dpkelly
22
Aug 2, 2014 08:21 PM
imzjustplayin
17
May 4, 2009 10:03 AM
civicdxguy
11
Jan 30, 2007 02:29 PM
GiMpInThaCiv
Mar 21, 2006 08:46 PM
