junkyard turbo?
http://www.homemadeturbo.com/
http://thenew.gamesbbs.com/~turbosi/
click on junkyard turbo list it has turbos from every kind of car you should look for and the type of turbo it is too
[Modified by Brandon Chun, 8:14 PM 10/5/2002]
ur probably gonna have to keep it non intercooled do to a limited amount of space up front and u may want to try and get rid of ac if u have it and push teh radiator forward....use a hf or similar manifold with a t3 or similar turbo T3;s are easy to come by......with that run the coolant and oil lines a bov from a volvo or something else....merceds,old DSM's etc.... uhhh some charge pipe(can use radiator hose) get a set of 450cc injecters and a afc or an inline fuel pump and a rising rate fuel regulator....i would go with injecters and a acf and a fuel pump good luck
Guest
Posts: n/a
Actually Radiator hoses work pretty damn good for charge piping.. suprisingly..
Jeff Frank
Jeff Frank
sorry for the lame questions but i'm curious...
Guest
Posts: n/a
i need 3" diamater coolant line. about 7802356782365767ft of it. i also need hose clamps. hondata / other standalone systems are not ecconomical on a jumkyard setup. 450cc jectors inline pump safc and your golden. fyi i HATE fmu's. i especially hate it when people use them in conjunction w/ standalone fuel management systems. its a really retarded way of managing fuel.
I don't remember seeing mandrel bent stuff there, only crush bent...
http://kjvieira.tripod.com/pics/grm_...rxfront-ic.jpg ***copy and paste the link in your browser since tripid is stupid***
i think that is the 87 teg radiator that we moved forward.
[Modified by breaka_1_9, 3:37 PM 10/15/2002]
anybody have pics of where the oil feed is from behind the block? i know its somewhere near the oil filter, but juss dont know which one it is...what other lines would one need to complete the set up...i know the oil feed, a line for the oil return...anything else? also, where do you go to get one of those adaptors for the HF manifold...anyone still got an hf man. for sale?
Dancing is Forbidden
Oct 27, 2005 06:33 AM
