f22 a/t transmission for f20b
Old Oct 14, 2011 | 06:12 AM
s0lid's Avatar
Default f22 a/t transmission for f20b
Hi guys,
I have an f20b a/t but the transmission si jerking and shifting hard. I went to the shop to replace it with another transmission but they only have f22 a/t transmission left would this work for me?
Old Oct 15, 2011 | 05:32 AM
Lost Again's Avatar
Default Re: f22 a/t transmission for f20b
Have you looked in the FAQ-IIRC, any 90-97 auto tranny will fit.
Old Oct 17, 2011 | 08:44 PM
s0lid's Avatar
Hi,
what's FAQ-IIRC i tried to find it here.
TIA
Old Oct 17, 2011 | 10:57 PM
nus_dogg's Avatar
The F22 Auto Trans will fit your F20B no problem. Gearings will be longer than a original F20B trans.
Old Oct 18, 2011 | 01:02 AM
mudpuppy4life's Avatar
hmm so i can put a s2k engine in my cd5 and use my 5 speed? hell yea! got my wheels a turnin now
Old Oct 28, 2011 | 02:07 AM
s0lid's Avatar
How about an A/T H22 transmission would the ratio be similar to f20b A/T?
TIA
Old Oct 29, 2011 | 01:54 AM
MAD_MIKE's Avatar
MM Gruppe B
mudpuppy4life he said F20B, not C.
Hard to say. Best guess is the F20 would have lower gear ratios than a F22 simply because the smaller engine would need lower gears for torque multiplication to move the heavier car.
My only concern with using a H22 transmission is the torque converter may have a slightly higher than desired stall speed. Would it be noticeable, dunno.
The Odyssey F series trans has similar, if not same, gear ratios as the H series transmission. But comes with a larger torque converter for a lower stall speed.
Measure your F20s TC and drive plate bolt pattern diameters. There are at least two different sizes I know of. If the transmission you pickup has a different diameter TC make sure you also get the driveplate that fits it.
*BTW which F20B do you have SOHC or DOHC? If its the DOHC then use the H22 transmission.
accordscantdrift
Sep 12, 2009 11:58 PM
russlan44
Oct 30, 2007 07:28 AM
slickrick88_2006
Apr 1, 2007 07:56 PM
idewson
Mar 16, 2006 02:09 PM
RonRon
Sep 17, 2002 10:12 PM
