2001 GSR cooling system issues
Old Oct 14, 2011 | 05:43 AM
1slo22cl's Avatar
Default 2001 GSR cooling system issues
Was driving to school this morning and saw some smoke coming from under hood. The temp gauge was less than half way, so I don't think this is an overheating issue. I checked the coolant level and it was fine (both the overflow bottle and radiator) The smoke was coming from in between the radiator and condenser, so I can't pinpoint what this is? Could it be the water pump? FWIW, it happened in traffic, I didn't see anything while driving on the highway.
Sorry if this is a dumb question, but this is obviously bugging me pretty bad.
Old Oct 14, 2011 | 06:07 AM
kyden's Avatar
Default Re: 2001 GSR cooling system issues
oem radiator? is it seeping between the seam at the plastic tank?
Old Oct 14, 2011 | 06:24 AM
thenoxus1's Avatar
Can you spot any leaks anywhere? It may just be a pinhole that opens more under pressure. When you get home, turn it on, and see if you can spot a leak as she warms up, just be careful to not overheat the thing.
Mitch
Old Oct 14, 2011 | 07:04 AM
1slo22cl's Avatar
I did notice a leak, but I'm 99% certain it was the bottle (which I just replaced) It just seems weird that the temp gauge would read out at less than half but see this smoke?
I topped the car off on coolant a couple days ago, and when I checked the level in the rad it wasn't low, so this makes me think that there is no leak coming from it.
Old Oct 14, 2011 | 08:21 AM
thenoxus1's Avatar
You're seeing smoke probably because coolant is leaking onto something hot and burning up. You may have a pinhole leak like I mentioned, not enough to show huge losses, but enough to spray some under pressure and smoke.
Old Oct 14, 2011 | 08:58 AM
1slo22cl's Avatar
That's what I thought originally, which is why I replaced the bottle (assumed it was leaking from there)
Old Oct 14, 2011 | 09:45 AM
thenoxus1's Avatar
Check all the hoses, coolant runs through an upper and lower hose, into the block, back on the IACV etc etc.
Old Oct 14, 2011 | 10:46 PM
RTUNED BUILT's Avatar
Lets stop geussing and do the right thing... do a coolant pressure test, thats going to detect any leaks on youre cooling system. its very easy to do only take bout 2 minutes to do with the pressure test kit..
Old Oct 14, 2011 | 11:06 PM
mouab18c1's Avatar
It's not your overflow tank. It's one of your coolant hoses. Use a pressure tester^^ if you can't pinpoint it.
RG400SmartTowel
Aug 11, 2009 12:34 AM
project civic
Mar 16, 2006 09:46 AM
ecks_fourttwo
Jan 24, 2006 07:41 AM
hyperazn108
Sep 13, 2004 10:11 PM
xrocket21
Jul 1, 2003 04:52 PM
