94 accord ex
Old Oct 13, 2011 | 04:32 PM
Amir717's Avatar
Default 94 accord ex
I just bought an accord tonight and the tail lights would stay on but we fixed that issue but my brake lights dont work what do you think could be the problem I looked at the brake pedal and its missing that rubber thing that goes into the hole if anybody could please help me figure it out I would greatly appreciate it thanks.
Old Oct 13, 2011 | 05:22 PM
Lost Again's Avatar
Default Re: 94 accord ex
Well back up, I'm old and slow....They were on and you fixed that-now they won't come on?
If the plug is missing, go get a new one ~$4 at the dealer---- 46505-SA5-000 is the part number at the dealer.
Old Oct 13, 2011 | 06:20 PM
Amir717's Avatar
My bad I should of clarified it a lil better. The light tail lights would stay on with the lights off. My friend somehow made the tail lights work right but the brake lights aren't coming on even though they are the same bulb. Is there a way of checking the switch on the brake pedal or would my switch work from my civic (just to see if that'sit) which is also a 94?
Old Oct 14, 2011 | 05:38 PM
Lost Again's Avatar
Most of the time those are "dual" element bulbs....so when the headlights are on one element lights up, when the brake pedal is pressed the "other" element lights up......so it sounds like "your friend" pulled the stoplight fuse from the under hood fuse panel....if the brake lights are on all of the time.....buy the dang plug and replace it...then replace the fuse so you don't hurt anyone because you are driving around with no brake lights.
Old Oct 15, 2011 | 01:26 PM
Amir717's Avatar
You were right it was the bulb and the thing that goes onto the pedal like a rubber piece that holds the switch in was missing but thank you!!
Old Oct 16, 2011 | 05:53 AM
Lost Again's Avatar
You got it fixed...that is what is important
Jonathang
Oct 10, 2014 03:50 PM
rgabriel
May 10, 2011 07:46 AM
T3k C
May 15, 2006 09:33 PM
slickrc
Jul 14, 2003 11:55 AM
