Misfiring civic
I have a 98civic and its misfiring but im not shore what it could be It a random the code that came out was P0300.. Its smell like gas a lot so im not shore if is the injectors or what Need help..
check the cap and rotor first then plugs , then changed the crank sensor if need be. if his ignition timing was never changed i dought that's the problem. did you buy the car like this or were u riding down the road and the CEL started flashing meaning a missfire.
