B16a2 more horse power
Old Oct 13, 2011 | 12:16 PM
OnlyJapan's Avatar
Default B16a2 more horse power
Hey Peps i have a question
I have a Civic EK4 SEDAN VTI v-tec 1.6 b16a2
what is the best header for a stock B16a2 and air intake i like to gain more horse power..
Old Oct 13, 2011 | 12:21 PM
grumblemarc's Avatar
The Grumpiest
Default Re: B16a2 more horse power
Define "best" and "more". What is your budget?
Old Oct 13, 2011 | 12:33 PM
OnlyJapan's Avatar
I mean best to gain horse power on a stock engine. And more like 10-20hp
Budget 1000$ only for header and intake i have a srs 2.5inc cat-back for now and supersprint 4-2-1 header but i think it is small
Old Oct 13, 2011 | 12:51 PM
The Grumpiest
If you want to blow that kind of money for so little power go see Bisimoto.
Old Oct 13, 2011 | 12:53 PM
TunerN00b's Avatar
Originally Posted by OnlyJapan
I mean best to gain horse power on a stock engine. And more like 1-5hp
Fixed, to represent realistic expectations.
Old Oct 13, 2011 | 12:58 PM
OnlyJapan's Avatar
What do you mean TUNERN00b what is not realistic 1000$ or 10-20hp for that budget??
i like in Denmark sow its much more expensive for me if i order from the states because shipment and taxes..
Old Oct 13, 2011 | 12:59 PM
OnlyJapan's Avatar
Live in denmark
Old Oct 13, 2011 | 01:02 PM
The Grumpiest
What part of this is confusing?
Old Oct 13, 2011 | 01:15 PM
OnlyJapan's Avatar
i dont know what he meens by fixed to represent realistic expectations. is it about the budget or to get 10-20hp whit a header and 2.5catback and air intake
Old Oct 13, 2011 | 01:16 PM
joeshmo's Avatar
He means there is no way you'll see anywhere near 10-20hp with a header and intake.
Old Oct 13, 2011 | 01:27 PM
OnlyJapan's Avatar
really not even whit a header and 2.5inc cat back + intake not even 10hp what do i have to do to get 10-20hp N/A on a stock b16a2
Old Oct 13, 2011 | 01:31 PM
The Grumpiest
Internals.
Do you really believe that hype in the industry that they try to spoonfeed you? That this part plus that part plus another part in total can equal XXXXX horsepower? That if you keep piling on the parts you can make whatever horsepower you want? Are you really willing to spend a thousand dollars or more for a lousy 20 horsepower that you might not even feel and won't make any real difference?
Old Oct 13, 2011 | 01:40 PM
EK-Chris's Avatar
Thats not what the stickers on the boxes say In all honesty, even headwork without cams will only generate <10 hp. Save your money for a B18C bottom end.
Old Oct 13, 2011 | 01:47 PM
OnlyJapan's Avatar
1000$ for parts is little when you live in denmark its much more expensive in Denmark then the states i know that 10-20hp is not much but it is a start and i only wont n/a hp
i have a freind that haves dc sport header and cat back cold air intake, on the dyno hi got 178hp on a stock engine B16a2
Old Oct 13, 2011 | 01:50 PM
The Grumpiest
Dubious.
I just found a thread ona forum where the guy had the following
JDM B16A
1 layer head gasket
skunk2 stage2 cams
skunk2 valve springs
toda header
apexi ws2 exhaust
carsound 2.5 cat
aem 3" cai
and only made 182 whp 128 ft/lb to the wheels. Even then people were calling BS.
Old Oct 13, 2011 | 02:02 PM
The Grumpiest
Here's another one
Hondata s100
Type R Intake Manifold
RC 370cc injectors
B16 port n polish head
Over sized stainless valves
titanium springs and retainer
Brian crower stage 2 cams
10:5:1 forged CP pistons
Only 168WHP.
Old Oct 13, 2011 | 02:24 PM
OnlyJapan's Avatar
5Zigen Header 94-01 Integra GS-R, Type-R B18C JDM 2.5" Collector
TIG extreme welding, full SUS304 stainless steel finished with super smooth polished inside/outside. Improvement and power rise of response of medium or high speed. 10-15HP increase. This one fits on a B16a2
Old Oct 13, 2011 | 02:29 PM
The Grumpiest
Do your research and stop believing everything you read.
"Because the entire powerband was shifted upwards and made more linear, peak horsepower topped out at 147.7hp - a median gain of 9.6hp. "
Old Oct 13, 2011 | 02:37 PM
The Grumpiest
Here. If you want to spend money.
http://bisimoto.com/store/index.php?...roducts_id=362
Get that one and a velocity stack.
Old Oct 13, 2011 | 03:39 PM
Julio@Bisimoto's Avatar
Stock head
Stock Bottom end
Bisimoto V2 Headers vs DC
440 cc injectors
Test Pipe
AEM Cold Air Intake
AEM EMS
2.50" exhaust
Stock Cams
Bisimoto Cam gears
9 whp peak gain with V2, and 6 wft/lbs of torque.
Old Oct 13, 2011 | 04:15 PM
TunerN00b's Avatar
Originally Posted by Julio@Bisimoto
Stock head
Stock Bottom end
440 cc injectors
Test Pipe
AEM Cold Air Intake
AEM EMS
2.50" exhaust
Stock Cams
Bisimoto Cam gears
Adjusted cam timing (assumed, or why have the parts?) and tuning.
Be honest Julio, how much of the increased power came from the tuning (both ECU and cam timing)? How much power would be gained without those two, but with the rest of the mods?
The B16, much like the B18C variants, is quite well built from the factory. Minor bolt on parts aren't going to provide nearly the same increase in power as they could on engines that are much less optimal from the factory.
Until shown otherwise, I'll stand behind:
I put an AEM CAI on my GSR for increased throttle response. On a dyno, I wouldn't expect to see any gains that weren't within the normal variance of measurement.
But I certainly don't know everything. Everyone should feel free to show me I'm wrong, if/where I am.
Old Oct 13, 2011 | 04:20 PM
m_shake's Avatar
A toda header is concidered pretty much the best OTS header for a b16, but you gotta pay to play for that
Old Oct 13, 2011 | 04:30 PM
low91rex's Avatar
Im gonna go out on a limb here but I believe if you were to install 2.5 inch mandrel bent exhaust (no cat), CAI, a good 4-1 rmf style header, and bigger throttle body on to a bone stock b16 if and only if you get a dyno tune a 10hp increase is not an unrealistic figure to attain. Get a baseline number get the parts have someone really good tune the car and just watch the magic. you'd be surprised to see what a good tuner can squeeze out f a healthy stock motor.
Old Oct 13, 2011 | 04:50 PM
This dyno comparison was before tuned with DC header and then after tuned with Bisimoto header. Only variable of this test was the header it self
Old Oct 13, 2011 | 05:27 PM
low91rex's Avatar
Good stuff
