remove door rod joint
Old Oct 13, 2011 | 11:05 AM
curtie94's Avatar
Default remove door rod joint
My passenger door opens hard and I wanted to adjust my door handle rod joint. I had the door panel off but couldn't get the rod off. What is the correct procedior to remove it.
The car is a 1991 honda accord 2dr
Old Oct 13, 2011 | 11:20 AM
redbull-1's Avatar
Default Re: remove door rod joint
You can try to pry it out with a flat head screwdriver or diagonal cutter (you're not cutting it, just using the cutter to pry it out). Good luck. You might want to wear some eye protection and gloves just in case.
Old Oct 15, 2011 | 06:12 PM
curtie94's Avatar
Ok I have removed it and adjusted the joint but if I have 2 threads like is says it won't even open. But It still opens hard. Dies it have to do with the seals on the door? Does anyone know how to fix this?
Old Oct 16, 2011 | 05:13 PM
curtie94's Avatar
My door seal is what was making my door stick. I sprayed it with wd-40 and it opens a lot better.
pdidnotkno
Sep 7, 2014 06:24 PM
bhath19
Apr 18, 2011 12:48 AM
curtie94
Feb 20, 2011 02:24 PM
paulhsu
Nov 22, 2008 03:30 AM
todd.ludwig
May 1, 2006 02:27 AM
