95 dx with a f22b1 swap..
Old Oct 12, 2011 | 12:51 PM
import image's Avatar
Default 95 dx with a f22b1 swap..
i have a 95 aaccord dx did put in a f22b1 now the car wont idile...wat can it b?...
Old Oct 12, 2011 | 01:45 PM
nus_dogg's Avatar
Default Re: 95 dx with a f22b1 swap..
Can you be more specific? What do you mean it won't idle? Car won't stay running right after your start it up?
It does crank over and fires up, right?
Old Oct 12, 2011 | 07:12 PM
4doorjdm's Avatar
Check your vacuum lines. especially the ones to the egr they may have got switch up in the swap. Or if the egr is stuck open it will cause no idle.
Old Oct 13, 2011 | 05:50 AM
no it wont pass 3500 rpms...it starts fine..
Old Oct 13, 2011 | 06:04 AM
nus_dogg's Avatar
Do you have a check engine light on at all? You're in limp mode.
Old Oct 13, 2011 | 09:37 AM
yes i do have the check engine light on...i changed the harness on the motor and distributor..
Old Oct 13, 2011 | 10:30 AM
TheMuffinMan's Avatar
He knows where you live!
ECU?
Old Oct 13, 2011 | 12:37 PM
changed the ecu...change the throttle body...and everything on the intake manifold...wat could it b....
Old Oct 14, 2011 | 08:07 AM
how can i check my ecu codes?
Old Oct 14, 2011 | 08:35 AM
If you're OBDI now there is a service connector that's blue behind/beneath the glove box.
Jump the connectors with a paperclip and it'll blink the CEL.
Old Oct 15, 2011 | 05:32 AM
how would i kno what the bliking light is telling me...?
Old Oct 15, 2011 | 10:31 AM
mudpuppy4life's Avatar
i searched "how to get codes from a obd1 honda" on youtube
Old Oct 16, 2011 | 05:10 AM
Enixero's Avatar
What really gets me is you can change all that stuff under the hood yet you don't know how to obtain codes from an OBD1.
Something doesn't add up there.
Sounds like LIMP mode, Tried pulling the fuse for the ECU and resetting everything, if that don't work then look up main causes for LIMP mode and work your way through the causes.
Old Oct 16, 2011 | 10:29 AM
Lost Again's Avatar
Enixero-you'd be surprised...
Haven't seen you in a while, hope things have been good...PM when you can.
OP-get the codes.....could be something simple.....new wires to the vtec???
Old Oct 17, 2011 | 01:10 PM
i just dont kno how to read it...i get it to blink...
Old Oct 18, 2011 | 04:52 PM
poorman212's Avatar
ok, count the blinks....there should be a pause between different codes or the same will repeat.
Blainet96
May 27, 2015 03:28 PM
Acemcguyver
21
Dec 9, 2014 06:57 PM
94_civic_dx
Jul 17, 2012 07:21 AM
bka112
May 14, 2007 09:14 PM
civcexcoupeblack
May 22, 2003 06:44 AM
