welding seat rails
Old Oct 12, 2011 | 04:37 AM
jsinher3's Avatar
Default welding seat rails
i have a 91 EF civic hatch im trying to swap integra DA seats into it im not going to do the seat pan swap, i want to use the civics stock seat rails and weld them to the integras seats. the problem is im not sure how to go about this is there a DIY for this or can anybody explain to me how i may accomplish this.. thank you in advance.
Old Oct 12, 2011 | 07:30 AM
jsinher3's Avatar
Default Re: welding seat rails
60 views and no response come on guys, at least point me to the right direction.
Old Oct 12, 2011 | 02:59 PM
914Racer's Avatar
It is not advisable to weld the rails directly to the seat pans. You are better off using the rails to match the seat and then welding the brackets you need to match the floor pan. That is much easier. You can built the brackets you need to attach it to the floor pan from .125 steel.
Old Oct 15, 2011 | 07:15 PM
jsinher3's Avatar
ok thanks do you know were i can pick that steel up?
Old Oct 15, 2011 | 08:59 PM
uberEFtuner's Avatar
I used prelude seats. I ground off the mounting brackets where the bolt go through the seats. The used the ones that matched up with the new prelude seats. Welded them on the new seats and Also welded a nut to the floor.
e13h
Feb 20, 2019 10:54 PM
bakoCRX
Jun 12, 2010 09:26 AM
RISING_SUN
Sep 30, 2009 03:59 PM
Got_EF8
Jun 23, 2009 09:56 AM
CeeJayy
Jul 28, 2008 11:36 AM
