Ef with b18b jerking while driving.
Old Oct 11, 2011 | 08:39 PM
10psiLsEf2's Avatar
Default Ef with b18b jerking while driving.
Hey guys im honestly at a stump!
This morning while going to work i noticed my car was jerking, like when a new driver cant drive stick but not so much!
This only happens at light throttle if i go WOT it feels smooth. i tried it in nutral also at light throttle and it sounds as if the rpm bounces just a little bit.
Please help me!
thanks
Old Oct 11, 2011 | 09:05 PM
10psiLsEf2's Avatar
Default Re: Ef with b18b jerking while driving.
anyone??
Old Oct 11, 2011 | 09:52 PM
10psiLsEf2's Avatar
Bummp. Come on guys.
Old Oct 12, 2011 | 02:45 AM
rd91sib18c5r's Avatar
I would check the tp sensor.
Old Oct 12, 2011 | 07:22 AM
Muckman's Avatar
Moderator in Chief
If it was fine before, then its likely fuel or ignition related. TPS and MAP sensors can also effect the ECUs fuel/ignition control as well. Check the basics first - distributor, plugs, fuel filter etc.
Old Oct 12, 2011 | 03:47 PM
10psiLsEf2's Avatar
thanks for the replies guys.
how do i test the map
Old Oct 12, 2011 | 05:20 PM
stock95coupe's Avatar
Use your GPS. J/k With key on & motor off, one pin will show ground, one +5 volts, the other should be around 2.7 volts (+/- half a volt). You will need a pin to stick in the connector as it's connected.
An easy test would be the oxygen sensor. If you unplug it it goes into open-loop (no fuel corrections) and will run better if it's bad. It will also go open-loop WOT, which is why it appears only at light throttle. A bad O2 sensor or the wiring could make it rich/lean at low load and sometimes show no code. If that fixes it, you need to fix the sensor or wiring.
Old Oct 14, 2011 | 04:50 AM
eldermichael's Avatar
So it feels like it's missing out?
Old Oct 18, 2011 | 10:06 AM
10psiLsEf2's Avatar
sorry for the late replies. been slammed at work.
sort of like missing. lets say im in 3rd gear at 3000 rpm just holding the throttle to maintain speed. it feels like the fuel cuts on and off or the spark on and off
(it starts jerking)
Old Oct 18, 2011 | 10:57 AM
grumblemarc's Avatar
The Grumpiest
Any CELs?
Old Oct 18, 2011 | 01:12 PM
207hondaguy's Avatar
Are you using an ems?
Old Oct 19, 2011 | 06:32 PM
mixineric's Avatar
I would try to remove your IACV and clean it or replace it. Had the same problem a few months ago and this fixed it.
Old Oct 19, 2011 | 06:44 PM
91crixls's Avatar
does it only jerk when you gradually let off or get on the throttle? or does it jerk while youre on the throttle? my old ls crx did that every once in a while if i was cruising and let off the pedal or put my foot back on the pedal barely, felt like the back motor mount wasnt attached or some ****. But check what the above posts said about the tps and iacv.
Old Oct 20, 2011 | 12:16 PM
Markyboy's Avatar
Sounds like a mass air sensor issue or iacv try to uplug the iacv a see if it corrects it self
Old Oct 20, 2011 | 12:31 PM
10psiLsEf2's Avatar
hondas dont run on a mass system they use a MAP system.
ive tried 3 different map sensors. same thing
Old Oct 20, 2011 | 12:32 PM
10psiLsEf2's Avatar
yea exactly what you said. on gradual throttle or deceleration only.
at WOT its ok.
Old Oct 20, 2011 | 12:33 PM
10psiLsEf2's Avatar
YES check engine for
02 sensor.
Old Oct 20, 2011 | 01:22 PM
Markyboy's Avatar
My bad I was thinking about my other car
Old Oct 28, 2011 | 07:24 PM
B20vREX-LD's Avatar
My b20 vtech is doing the same thing is extremly annoying and look like a sped when I'm driving it
Old Oct 30, 2011 | 02:51 PM
driftn_silvia's Avatar
10 Year Member
you should check the TPS.
Old Oct 30, 2011 | 06:57 PM
10psiLsEf2's Avatar
took off my 74 mm throttle and put the stock one. calibratd tps and it runs good now
Old Oct 30, 2011 | 08:36 PM
Muckman's Avatar
Moderator in Chief
Did you try calibrating the TPS before?
Old Oct 30, 2011 | 10:21 PM
LightningTeg's Avatar
Community Builder
Sounds like TPS may be intermittently cutting out so the ecu thinks your jabbing the gas and it will want to inject a bunch of fuel to compensate.
evlgsr
Engine Management and Tuning
Jan 9, 2017 01:27 PM
Migs19
Mar 29, 2016 08:53 PM
4drcivicls
29
Aug 12, 2007 06:31 PM
wilham320
11
Feb 24, 2007 03:07 AM
Chico90hb
Oct 5, 2005 09:42 AM
