heater control knob is really difficult to adjust
Old Oct 11, 2011 | 08:07 PM
noobaccord's Avatar
Default heater control **** is really difficult to adjust
hey guys so i've been having some trouble with my car when i try to adjust the temperature **** inside the car. it's extremely difficult to turn the **** and i have broke the **** a few times and i now just use a pair of pliers.
i'm really not sure how to fix it. a friend of mine said there is a cable that might need to be adjusted or lubricated. can any one help?
thanks!!
Old Oct 11, 2011 | 08:31 PM
bdmlilburn's Avatar
Default Re: heater control **** is really difficult to adjust
hey buddy. my 94 prelude and 90 accord both do the same thing. im sure taking the dash temp gauge out and making sure all the moving parts are greased/lubricated correctly to remove loss of travel. or possibly searching a junkyard for another temp gauge would work
basically our **** is old so the dust over the years gets stuck in the grease that lubes the moving parts inside the temp gauge and clogs it reducing travel. just gotta clean those moving parts thoroughly and grease them up again and throw the gauge back in the dash. but for some reason i just have not felt like getting all into the dash so mine never got done.. yes im talking about the temp **** not the actual coolant gauge.
Old Oct 13, 2011 | 02:46 PM
Lost Again's Avatar
What year are you driving.....most of them had two cables-one from the **** to the blend door-the other from the door to the control valve. If you have a manual, look at the blend door adjustment.
Old Oct 13, 2011 | 07:44 PM
ilikehonda's Avatar
go to a dealer and tell the parts dept what is going on. the will give you a little metal sleeve that will go inside the **** and will keep it from breaking. it is an issue with all of the accords 90-97
Old Oct 14, 2011 | 06:43 PM
Lost Again's Avatar
REALLY? A few things, first the dealer isn't going to "give" anything...second the ***** usually break the outer plastic-but you wouldn't know that.....so if anything, there should be a sleeve for the outside of the plastic where it goes on to the shaft.......please tell us the part number for this free, magical sleeve?
Old Oct 15, 2011 | 01:19 AM
cheggie's Avatar
I have found the heater valves can get hard to turn over time. If that valve is stiff, it will be very hard to turn the temperature blend ****.
Old Oct 15, 2011 | 10:17 AM
bdmlilburn's Avatar
i actually noticed this last night when bleeding the coolant. my old coolant system had all kinds of scale in it so i dont doubt the valve needs replacing
Old Oct 15, 2011 | 12:31 PM
P_Adams's Avatar
It's going to be a matter of working backwards from the hot water control valve to determine whats going on.
Whats involved her is this:
1) Temp control **** / Heater control assembly.
2) Cable #1 - This runs from the control head to the Heater Box's temperature control door actuator arm.
3) Cable #2 - This runs from the Heater Box's temperature control door actuator arm to the Hot Water Control Valve.
4) Hot water control valve.
I would start with inspecting the HWCV. It is the most common failure for this (besides the busted temp **** :-( and is the easiest to reach.
Disconnect the control cable from the Valves actuator arm and check if it (the valve) operates freely. At the same time, operate the control **** and note if it works any easier.
If the valves binding; great - replace it. If it is NOT binding; order BOTH temp control cables (and their retainer clips) from your favorite Honda source. Fixing this will then require delving into the dashboard and you'll want all possible replacement parts available cuz you don't want to do this twice !!
Old Dec 17, 2014 | 07:02 PM
spiritofdscvery's Avatar
Is there any specific grease you would recommend for the temperature controller? The plastic parts I cleaned had old looking cream/dark yellow grease (similar to what I am seeing all around in the A/T Gear shifter panel). I used a freshly bought CRC White Lithium Grease (spray can) on the glove box key cylinder and it "appears" to have done the job, though at first it appeared slightly sticky and not greasy; perhaps that was just the cold temperature of the grease when it comes out of the can. Any help/tips on this are much much appreciated! Thanks!
Old Dec 17, 2014 | 08:28 PM
holmesnmanny's Avatar
Its likely the cable is binding. Pop off the plastic cover at the bottom passenger floor and check the cable.
Old Dec 17, 2014 | 08:59 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
thats probably white lithium grease, the stuff in the tube and the spray can are the same grease
Old Dec 18, 2014 | 06:21 AM
Thank you!! :-)
Old Dec 19, 2014 | 06:47 PM
Thank you!! :-)
anything you see with grease on plastic parts, it's most likely white lithium, the stuff will turn yellow and get nasty looking with age
Old Dec 22, 2014 | 04:11 PM
Ah, that's what I was thinking, thanks for the confirmation, good to know I am using the right kind of grease.
On a tangent, though relevant to the heater control panel, does anyone know the specs of the small spring that goes where the picture indicates? This part is part of the temperature controller assembly. Would this spring be listed in the service manual or would it be available only as part of the larger part? And... should I repost this as a separate thread? Thanks!
Got_soy
14
Jul 8, 2006 12:47 PM
RTW DC2R
Apr 9, 2006 09:29 AM
mrb18c
Jan 13, 2004 05:10 AM
chhuong
May 29, 2003 02:42 AM
Cone
Apr 8, 2003 09:44 AM
