K series swap parts, K20, K24 misc for sale!
Old Oct 11, 2011 | 11:00 AM
dschybrid's Avatar
Default K series swap parts, K20, K24 misc for sale!
Whatever I list is for sale, the prices are NOT with shipping.
  • FIRST COME FIRST SERVE
  • PAYPAL & CC's are accepted
  • Message me for shipping
  • 225-755-8211 (call, NO texts)
  • David@hybrid-racing.com (EMAILS GET ANSWERED BEFORE PM's!)
PRB Intake Manifold (K20A2) x1 - $30
K20 Timing Chain Cover x4 $10ea
K20A2 Camshaft Sets (1 Intake and 1 Exhaust Camshaft) x2 $100per pair
Intake and Exhaust Camshaft. Does NOT include cam gears. One pair has a little surface rust, will come right off if rubbed with a scotch brite pad.
K20A2 Water pump and Housing x1 $50ea *Comes with auto-tensioner*
K24 Water pump and Housing x2 $25ea
K24A1 Head x1 $150
Includes Head, Cams, Cam Caps, Rockers, Valve springs, and Bolts.
GoPower K24 bare block bored to 87.5mm x1 $400
Will open the packaging up if someone is seriously interested. No crank.
Wiseco 13.7:1 Compression Piston Set at 87mm (brand new, never used) x1 $300
Can be used in 87.5mm with oversized rings
Wiseco 11.7:1 Compression Piston Set 86mm k573m86 (new never used) x1 $300
Can be used in 86.5 with oversized rings
Used Competition Clutch sprung stg. 4 with matching lightweight flywheel x1 $300 for both
Roughly 3000 miles on them.
DSS "used" 2.9 K-swap axles. For EG subframe or EK with EG subframe x1 $300 ONE SET LEFT
*No pics*
SSR K-swap header x1 $700
*No pics*
Skunk2 60mm Exhaust for EK hatch x1 $200
K20A2 mildly built engine x1 $2500
K20A2 Motor built by BluePrint Racing. Long Block only. BluePrint I-beam rods, Wiseco 11.5:1 pistons, BC stg.2 camshafts. Might have 1500 miles on it. Engine was broken in properly with ND-30 weight oil and has been changed 5 times with new filter every time. Never brought over 8600 rpm. Made 244hp and 172tq.
USED Kinsler ITB's for K-series 57mm x1 $1800
Comes with -10 fuel rail, Honda TPS adapter, Modified K20 water pump housing, RDX injectors & Air horns!
USED K20A2 Transmission with OBX LSD (2nd gear grinds at high rpm) x1 $600
Does not have a reverse lock out solenoid
Please call, pm or email me with questions. This stuff is priced to sell quick. Anyone interested in multiple parts will be offered package pricing.
Thanks for looking!
-David
Old Oct 12, 2011 | 07:06 AM
dschybrid's Avatar
Default Re: K series swap parts, K20, K24 misc for sale!
Bump!
Old Oct 12, 2011 | 12:21 PM
dschybrid's Avatar
Slicks, header, intake, one set of axles, timing chain case and RBC manifold sold!
Parts in the post are still available!
Old Jan 2, 2012 | 02:23 PM
FunkyFresh_EK's Avatar
10 Year Member
bump.. can u send me pic of the axles plz? 32mm or 36mm?
Old Jan 3, 2012 | 01:21 PM
DA9DC4's Avatar
Bump good stuff might be contacting you!
jimmyjun0213
May 27, 2015 07:37 PM
XDeath
Nov 22, 2011 06:51 PM
formervendor
Oct 30, 2011 07:46 AM
turboDeznutz
Oct 8, 2006 06:37 PM
vtec_powah
Sep 16, 2001 03:54 PM
