Another garage sale thread
I had another for sale thread but since it's 3 pages long and has information all over the place I decided to make a new one with the parts that I still have up for sale with the new prices. So here it is.
b16a2 block/crank $75
T70 turbo $150
Intake Manifolds $25
DSM SMIC $25
oil pressure gauges x 2 $25 per
B18b dizzy with msd cap/external coil ngk wires $150
bbk 70mm tb $75
2 Flywheels (b18) $25 per
B18b Axles/mid shaft $25 per set (torn boot on 1 axle)
b18b1 ls ARP head studs (properly torqued one time) $50
Supertech valves for b18b1 (stock size) $100
M9A1 92fs Beretta 9mm $500
T70 turbo $150
DSM SMIC $25
bbk 70mm tb $75
BBK tb - SOLD
b18b axles - SOLD
Autometer gauge - SOLD
92FS M9A1 9mm - SOLD
Still have some other parts. I am willing to and would much rather trade what I have for these parts...
Victor x intake manifold (ITR)
1,600cc injectors
10 gallon fuel cell
750+ FMIC
Stage 5 or higher clutch
Large fuel rail
b16,b18c transmission WITH LSD!!!
After market vtec cams
That's about it. I will also do partial trades. Thanks.
b18b axles - SOLD
1,600cc injectors
10 gallon fuel cell
750+ FMIC
Large fuel rail
I have some new parts that I might be selling.
P72 stage 3 race head from Slowmotion Motorsports - $2,000 OBO
over sized supertech valves, supertech springs, retainers,keepers, oem guides. It does not come with cams. But it does include vtech solenoid and valve cover. Everything has 0 miles on it. It is basically this but with a little more porting...
http://www.youtube.com/watch?v=xtyaG...el_video_title
Up next is my back up motor.
Fully built stock 81.5mm stock sleeve b18b1 - $2,000 OBO
All work was done by Jon at Moorespeed Performance. Motor has 0 miles on it. New water pump, oil pump. All clearance were on the looser side because I was planning on 500-500whp with this motor. Use oem honda bearings and acl bearings for perfect fit.
-CP 9.0:1 pistons
-manley h beams
-arp everything
-polished, balanced crank/rotating assembly
-block guard
-all machining was done at Fowlers
-assembled by Jon Moore
I think thats about it for the motor. Obviously it is built for boost.
Let me know if you have any questions.
-CP 9.0:1 pistons
-manley h beams
-arp everything
-block guard
