quick question with probably an easy answer
Im in the process of a Koni-GC set up on my car and after i took everything out and took off the spring i noticed that there were no rubber bushings under the strut cover (refer to pic........ #13 ) I see these bushings in practically every diagram and am curious if its something i should buy new and put on or if i dont have to worry about it. Might be a noob question but i cant quite find the answer for it so im asking for help.
btw i realize that is a diagram for an accord I didnt feel like re searching for specifically a prelude but the components are all relatively the same.
Yeah thats what i figured but shouldnt stock shock and struts have these bushings? All i saw when i took the cover off was a metal spacer with this grainy material around it. Now either the bushings were so bad that they corroded away or this "soil like" material was used as a substitute to reduce the impact on any bottoming out.
haha my other thought. Thanks i appreciate the info. now gotta find a place to pick some of them up. actually now that i think about out i dont even kno if the stock bushings would have fit anyways because of the thicker rod with the konis
