Weird problem with my EF
Old Oct 10, 2011 | 12:29 PM
cadetBOMD's Avatar
Default Weird problem with my EF
Hey everyone, this is my first post here, I appreciate every and any replies.
I recently bought a EF9 STD and whenever the car is running, and i press the brake, the door chime goes off. its quite irritating. please help. thanks.
Old Oct 10, 2011 | 12:36 PM
Efhatch277's Avatar
Default Re: Weird problem with my EF
Ive never heard that one before
Old Oct 10, 2011 | 12:37 PM
cadetBOMD's Avatar
no kidding. no one has heard that one before. lol.
Old Oct 10, 2011 | 12:47 PM
lunalink's Avatar
just remove the 15v fuse for interior/dome light it'll be gone until you find the bad wiring
Old Oct 10, 2011 | 12:50 PM
Efhatch277's Avatar
The door chime wire is in the driver kick panel, and the brake wire is above the brake pedal, so unless one is gounding out somewhere, that shouldnt happen
Old Oct 10, 2011 | 12:52 PM
cadetBOMD's Avatar
thank you! i will check it out. hopefully its a success.
Old Oct 10, 2011 | 01:44 PM
cadetBOMD's Avatar
okay. i checked the fuses under the dash and the interior lightings/clock fuse was blown, so i replaced it. turns out, that the actual door chime makes a different noise. it still made the beeping noise and it illuminated the door light on the cluster when stepped on the brake. so i cut the wires that was above the brake and it took the noise away.
how do i fix this? i know i need to reconnect the wire i cut, but i know that stupid irritating noise will come back. im stumped. thanks.
eg:R
Dec 27, 2011 08:07 AM
WinstonSmith
Jun 30, 2011 11:38 AM
IntegraGuy16
Jul 30, 2010 10:33 AM
dougb77
May 8, 2006 02:20 PM
AccordCD5
Mar 21, 2004 10:14 PM
