92-95 Dash Removed Ground's And Relay Question?
I have a 92 si hatch which i Just removed the dash from out of. Now i have not found one missing wirer but the ground from the Neutral Safety Switch that looks like it's been cut, other then that i think i removed it for no reason.
My question is the car was running with out the safety switch working , And there is 3 relays inside under the driver side dash section, What are they for and what do they control.
My car has been doing some funny things like the fuel pump wont start,
My car has new fuel pump and main relay, and i have tested the float sensor and the fuel connection?
I am lost. pls help befor i put dash back in thanks.
Its not my ecu because the check engine light will stay on the pump kicks on and the car will start and run? So...
I just picked up my eg and it has a switch wired to the fuel pump with power to the switch tapped into the #1 fuse under the dash (sunroof relay, which i don't have). works perfect for me but thats just to make it work for now
slowassBubble
Mar 17, 2011 06:12 PM
wvfarmboy
Feb 24, 2008 05:13 PM
sicivic
Jul 8, 2003 05:29 AM
