Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Codes 1298 and 1457 2002 CIVIC Sedan DX
Old Oct 10, 2011 | 06:10 AM
66fastbackbhoy's Avatar
Default Codes 1298 and 1457 2002 CIVIC Sedan DX
[B]As above i have the following codes that come on #1298 ELD Circuit Shows one time
#1457 shows 2 times, Any one know what this could be.(gas cap)
1298? I have No Idea , A.R.V Test shows Charging system works good
The codes were cleared a few days ago but only showed 1457 at that time
car seems to be running fine?
thanks for any advice
Old Oct 13, 2011 | 10:13 AM
Rayred's Avatar
Default Re: Codes 1298 and 1457 2002 CIVIC Sedan DX
1457 is a long time problem. From what I have read there is a solenoid that allows vapor from the gas tank to vent to the iand give you that error codentake manifold. The connections to the solenoid may fail occasionaly. I took my '02 to the shop and they charged me $67 to reset the code, but they never fixed the problem. It won't affect engine performance, (I still get 42mpg), just reset it and go.
Old Oct 15, 2011 | 12:45 AM
lazlong's Avatar
I've seen P1298 cause random codes to appear. Replace the ELD and the other code may go away. It's part number 38255-S5A-003. Ask for that specific part or they will try to get you to buy the entire fuse/relay box @ $250.
Old Oct 17, 2011 | 03:48 AM
Thanks Guys I will take your advice and try.
jimmy
rfazio
Feb 13, 2012 09:43 AM
chevyluver85
Dec 24, 2008 09:32 AM
tecmand
Jan 2, 2007 06:10 PM
bmow
Dec 11, 2006 06:01 PM
Tad
Jul 22, 2005 12:48 AM
