Plug wires every 10 months
Old Oct 10, 2011 | 05:39 AM
turkaloo's Avatar
Default Plug wires every 10 months
Hi all,
I decided to join the forum after fighting with my 99 Honda Accord for almost 3 years now.
The symptoms are shaking engine/misfire. I run the codes and I get low 300's (301, 302, 303,304) .
The solution every time has been to replace the plug wires. I believe plug wires should last much longer than 10-12 months. Could there be too much voltage going through the plug wires and if so, how is it regulated?
Thanks
Old Oct 10, 2011 | 06:05 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Plug wires every 10 months
What are you using to "run the codes and get low 300's"?
The Check Engine Light codes are one long flash followed by a short flash - yielding a ## format. Are you using some generic scanner?
And what brand(s) of wires are you buying? And have you replaced spark plugs?
*edit*
Whoops, realized you're OBDII - not OBDI
https://honda-tech.com/forums/tech-misc-15/heres-list-obd2-codes-if-anyone-cares-466877/
Low 300's then would indicate a misfire. Have you replaced spark plugs and distributor? (Brand is still important)
Old Oct 10, 2011 | 07:32 AM
GhostAccord's Avatar
I think Muffin means have you replaced the spark plugs and distributor cap and rotor, not the entire distributor...........
Old Oct 10, 2011 | 07:49 AM
Old Oct 10, 2011 | 09:43 AM
turkaloo's Avatar
I have replaced the distributor cap, not the rotor, and I replaced the plugs when I replaced the plug wires 2 days ago.
I scanned the codes with an Actron CP9125.
The car is running good again until the next time I will have to change the wires again prematurely.....
Old Oct 10, 2011 | 09:58 AM
motegicivic's Avatar
What brand wires?
I am wondering if you have an issue with the coil or distributor.
I would test the coil first.
Old Oct 10, 2011 | 10:09 AM
redbull-1's Avatar
For the 1999 Accords, the coil is internal within the distributor.
Old Oct 10, 2011 | 10:32 AM
What brand of stuff did you replace it with?
Hondas can be finicky with certain brands, and you're best to stick to the OEM.
Old Oct 12, 2011 | 06:56 AM
turkaloo's Avatar
The plug wires are Autolite professional series from Advanced Auto and the plugs are NGK iridiums
Old Oct 12, 2011 | 11:47 AM
jdmcertified909's Avatar
Im guessing your running completely? Autolite wires=nono oem or ngk wires. Honda dont like anyother brand not well insulated like ngk or oem. Other brands start leaking voltage thru the wires causing misfire. Copper wires is what you want.
Old Oct 12, 2011 | 04:30 PM
exb18c1's Avatar
Hi all,
Thanks
Does the problem go away right after the wires are changed?After you erase the codes it really takes a year to come back?I'm trying to see if the misfire codes are related to the ignition problem and nothing else.
Old Oct 13, 2011 | 04:15 AM
turkaloo's Avatar
exBi8c
The misfire codes go away immediately but I still get a different code or 2 for emissions. I don't remember off the top of my head what they are but when I looked them up in the past, people suggested changing out the catalytic converter and possible an O2 sensor. I will run the code checker and see what the codes are tonight.
Old Oct 13, 2011 | 10:34 AM
Pull your spark plugs and see what the tips look like. The condition of your spark plugs can tell you some things about how well your car is running and what could be the cause of any issues.
Old Oct 13, 2011 | 01:00 PM
OMG change those wires.
I had the same problem, mine were less than 2 years old and went bad on me.
redturds
Honda Civic (2001 - 2005)
Sep 16, 2018 09:05 AM
OrangeTeggy
Apr 4, 2009 12:43 PM
boostlude
Oct 3, 2005 04:37 PM
PokeyD16Z
Jul 26, 2003 01:31 PM
Wazup
Nov 11, 2002 01:15 AM
