FS:WELL built 95 teg Columbus $8k OBO
Old Oct 9, 2011 | 07:22 PM
x still jaded x's Avatar
Default FS:WELL built 95 teg Columbus $8k OBO
looking to sell 95 integra with full turbo kit. asking 8000 OBO
dont need a fast car anymore. trying to avoid speeding tickets. have documentation and receipts and dyno sheets.
GSR Black leather interior
GSR Gauges w/ 8200 rev limit
Custom gauge bezel (holds two gauges)
Oil PSI autometer Ultralight gauge (+ electrical sending unit)
Boost autometer Ultralight gauge
Apexi Turbo timer
Custom Billet "Turbo" foot pedals
Alpine Head Unit
Infinity 6in door speakers (front)
MTX 6in door speakers (Rear)
Complete monster wiring (RCA, Remote)
Viper alarm
Exterior:
S2000 antenna
Type R Spoiler w/ LED
17in Polished Wheels w/ tuner lugs
01 GSR all red tail lights
Clear front bumper lights
Deadbolt (engine disable) hood lock
Engine / Performance
B18a1 .20 over balanced/blueprinted block
ACL Complete Bearing set
GE Block guard
JE Pistons
Eagle rods /ARP rod bolts
JE rings
ARP Studs
STR Polished cam seal
All new seals/belt, Sensors, Water/Oil pumps
Balanced/ Micro-polished Crank
Fully ported B18b1 Head (Port matched intake to JG runners, exhaust to manifold runners)
3 Angle valve job
Crower SS oversized valves
Crower titanium retainers
Crower dual valve springs
B18b Polished cams
JG Edelbrock Victor X Intake manifold
Carbing oil catch can
AEM Fuel rail
AEM Fuel filter
AEM Fuel pressure regulator
Dual tapped B18b Oil pan (-10an)
SS Oil feed line/relocation line & fittings
Stainless Braided Fuel line
Walbro 255 lph High flow fuel pump
780cc Precision injectors
AEM EMS
AEM Uego w/ N² Custom mounting plate
Garrett/Air research 60-1 78 trim turbo (.48ar/.70ar)
Custom 2.5 stainless Intercooler piping / hose couplers
HKS SSQV Blow off valve
Tial Silver Waste gate
Custom Stainless Turbo manifold
Custom Dump tube
Custom Stainless 3" Down pipe
Thermal Research & Developement 3" Stainless Turbo Catback
Custom Air filter
Custom AC Lines w/ Thermal sleeving
Custom stainless braided oil return line w/ Thermal sleeving
MSD 6al Ignition
MSD Digital Blaster coil
Custom Ignition mounting plate/bracket
MSD Distributor external cap and wire
MSD Plug wires 8.5mm
Fluidyne oversized dual core aluminum radiator
Custom coolant overflow can
Custom Radiator mounting brackets
RPS 470 ft lbs torque clutch/pressure plate
OEM Throw-out bearing
GM Synchromesh Trans Fluid
NGK Plugs 7* colder
Oil filter relocation kit (Custom stainless braided setup)
Custom polished oil cooler
Custom High PSI -10an Oil lines and anodized fittings
RevHard Stage III Intercooler (32x9x3)
Nuespeed Short Shifter
Prothane Shift bushings
Suspension:
KYB AGX 4 way adjustable struts
Eibach Proline lowering springs
Nuespeed Rear lower Strut bar
Custom L-Con Traction Bar
Custom Polished upper strut brace
Energy suspension motor mount inserts
Brakes:
SS brake lines
Wilwood Big brake kit (4 piston calipers/ Oversized rotors)
New OEM Honda 1" master cylinder
Contact me by TEXT OR EMAIL ONLY I WILL NOT REPLY ON HERE I DONT HAVE TIME
Justin#614-565-7920
yahwehsrvt@wowway.com
Old Oct 10, 2011 | 08:02 AM
Default Re: FS:WELL built 95 teg Columbus $8k OBO
Wow....over 100 views with no bumps...come on!
Old Oct 10, 2011 | 09:54 PM
ehybeech95eg's Avatar
ttt
Old Oct 11, 2011 | 07:45 AM
maxwellmercer's Avatar
Tuned? Numbers?
x still jaded x
Oct 4, 2011 01:26 PM
WhoNeedsVtec
Oct 18, 2007 12:01 PM
Sunrise City Rider
Jan 2, 2007 04:06 PM
