94 integra ls Starter Bolts
My starter broke the other day and is now being held by one bolt !
atm i don't have the money to fix it, So in the meanwhile i am planing in "fixing"
the broken side with a bolt and washer combination.
Does somebody know the Size of both lower and upper bolts?
Why not just hit up your local bone yard, [PicknPull] and get one from there, probably not more then $1, or pull the other one and take it to a fasteners shop or maybe even your local car parts store so they can match it up. 94
Ok so my Idea does not work
It seems the starters gear does no engage the fly wheel Unless held with the help of a Person.
I don't have enough money for a new starter & decided to look up Craigslist
and i found some but im not sure which one is right
I know its a noob question but which of these is the correct one for me?
http://seattle.craigslist.org/see/pts/2644333629.html
Or
http://seattle.craigslist.org/see/pts/2648781301.html
I have a 94 Integra LS
Or
You have a ls therefore you need a B series starter "Second link".
It's a simple fix. As for the bolts just hit up a local Honda/Acura dealer. Pretty cheap.
Dont replace your entire starter because of one bolt..... Order the bolt from honda or something....
EDIT: yes as moua said, 2nd link, you have a B series motor, not a d series motor. Welcome to hT!
exxybihon
Aug 28, 2008 09:57 PM
