93 Civic - fuel pump won't prime and engine won't start
Old Oct 9, 2011 | 05:51 PM
11winkler's Avatar
Icon3 93 Civic - fuel pump won't prime and engine won't start
So my 93 hatch with b20 vtech swap stopped running one day while driving like it ran out of gas. I put gas in it and the fuel pump wouldnt prime.
I have changed the fuel pump the main relay and checked the thermostat ground.
I do not know what else to check. When I go to start it all it does is crank over like it would to start. I checked my ecu to see if it had any kind of short in it which it looked like it did so i bought another ecu had it chipped and tuned to my map and that didnt help either.
Anyone that is able to put any input on this would be greatly appreciated, i really need help here.
Old Oct 9, 2011 | 06:34 PM
Former User's Avatar
Default Re: 93 Civic - fuel pump won't prime and engine won't start
thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
Is fuse 31 or 24 blown?
Is there spark at the plugs?
Old Oct 9, 2011 | 08:12 PM
11winkler's Avatar
soory first post i have done.
None of the fuses are blown I cant check for spark until tomro
would the dizzy not having spark effect the fuel pump?
Old Oct 9, 2011 | 08:14 PM
10psiLsEf2's Avatar
if spark and fuel go out together, then possible (crank angle sensor)
Old Oct 9, 2011 | 08:25 PM
11winkler's Avatar
Thats located where first time i have heard of it
Old Oct 9, 2011 | 08:30 PM
10psiLsEf2's Avatar
OBD-1 has them inside the dizzy.
Obd-2 has it near the harmonic balancer.
Dont go changing parts until you properly diagnose the problem.
Just saying a bad crank sensor is a possibility
Old Oct 9, 2011 | 08:38 PM
11winkler's Avatar
alright thank you at this point i am willing to try anything
car has been sitting for a month because of this.
Old Oct 9, 2011 | 09:03 PM
Schulok's Avatar
I know this might sound like a stupid question, but you never know. Have you checked your fuel filters, maybe you got some dirty gas?
Old Apr 18, 2012 | 08:52 PM
kaves420's Avatar
i have the same problem but mine started bogging at 2k rpm and now it turns over but wont start...and i also dont hear fuel pump prime.. i changed fuel filter and bolt the connects fuel line to filter
Old Apr 18, 2012 | 09:49 PM
nihad's Avatar
also main relay.. for 15$ i have the newer ones and older ones..
Old Apr 19, 2012 | 07:53 AM
cryptonik's Avatar
Had sort of the same issue on my '92 hatch. Popped out the main relay and found a cold solder crack. 5 mins and a soldering iron and it was running again.
Old Apr 19, 2012 | 08:42 AM
beecee18's Avatar
ignition switch
ignition switch
ignition switch
Old Apr 19, 2012 | 08:46 AM
beecee18's Avatar
use this site to help narrow down where the problem is
since you have already replaced certain items with hopefully known good parts,
start with ignition switch diagnosis
www.tegger.com/hondafaq/startproblems.html
Old Apr 24, 2012 | 06:27 AM
kaves420's Avatar
So i changed fuel pump and it primes but now car turns over but it wont start...any ideas??
Old Apr 24, 2012 | 06:32 AM
nabin's Avatar
burn your car....... check your timing, do a comp test..... maybe your timing belt was loose or you bent a valve..... explore all options. fuel, compression, and spark make it run.....
ZachWood
33
Feb 22, 2015 02:34 PM
MY934dr
May 28, 2013 12:50 PM
EGGHEAD12
Apr 20, 2012 02:41 AM
Josh_Hoskins
Jun 21, 2011 07:26 AM
blu3g
May 29, 2008 05:18 PM
