Concerns with welding mild steel
I am a beginner tig welder It's my 5 time welding i started with aluminum and now am trying to weld mild steel. Today was my first time welding mild steel, 1/8 in. thick mild steel useing ER70S-2,3/32 filler rod at about 90 amps. My concerns are when I was welding aluminum once the puddle got initiated and once i started dipping the filler rod in it flowed into the puddle very smoothly and consistently. Now when I try mild steel once i get the puddle initated and start dipping the filler rod it dosent flow very well. It keeps sticking to the matterial and i have to quickly pull it off so i can try and add more filler rod. And becuase it keeps sticking and not really flowing very consistently it's not making my bead as uniform as it should. Do i need more head , different filler rod, whats causing this. I'm useing Orange tungstein btw
Thanks Brian
Thanks Brian
you can use the orange tunsgten, nothing wrong with that. i only use red tho i like it best. all we have at work is red for mild steel and stainless and brown for aluminum
ok which one should I get ? .035 .045, or 1/16th I want something Thats a good all around size something that will work at lower amps and is also big enough if i ever need to turn the amps up. And how come aluminum is so much different ? I used 3/32 with aluminum and that just melted right away.
Thanks again for all the help.
honestly get both .045 and 1/16th wire, depending on what your welding youll use both alot. thinner stuff youll want that smaller wire instead of using those little bit of amps to melt in the 1/16th wire
er70s-2 is fine.
er70s-2 is fine.
Yup, get both .045 and 1/16. Depending on what you're welding and how you're welding it (straight weld vs fillet weld) you'll want to use both and it will give you a feel for how different sized filler metals work within your puddles at different amperages.
ok thanks I baught them just waiting for them to come in ill post some pics it's only my 5th time welding so hopfully the smaller size rod will do the trick.
I have smaller Filler rod on it's way I was wondering also is my tungstein to big ? i'm useing 3/32 should I switch to a 1/16 or is 3/32 ok ? Is there a general rule of thumb for which size per amps.
I use 3/32 for almost everything for car stuff use 3/32 and your 1/16 rod and you should be happier learning with that
Justin Olson
Welding / Fabrication
Aug 31, 2007 06:30 PM
Fred Allen Burge
12
Apr 4, 2006 10:23 PM
