TDC piston?
Old Oct 5, 2002 | 02:13 PM
B18 civic's Avatar
Default TDC piston?
Hey guys how can you tell if number one piston is TDC (top dead center) without removing the head? Need help fast...thanks
Old Oct 5, 2002 | 02:16 PM
Paste's Avatar
Loved
Default Re: TDC piston? (B18 civic)
From the marks on the camgears
Old Oct 5, 2002 | 02:50 PM
Rhetoric's Avatar
Default Re: TDC piston? (paste)
Line up the crank pulley mark as well.
Old Oct 5, 2002 | 02:52 PM
vteg's Avatar
New User
Both cam gears up marks pointing up.
http://www.c-speedracing.com/howto/v...lveadjust.html
Old Oct 5, 2002 | 03:09 PM
typealex2's Avatar
Stick a screwdriver shaft down the spark plug hole.When that stops moving up you have TDC.
Old Oct 5, 2002 | 03:19 PM
baonest1's Avatar
Default Re: TDC piston? (typealex2)
the crank pulley is always align because of that little pin right. i dont have to line things up to put the pulley on?
thanx
Old Oct 5, 2002 | 04:59 PM
Batoutahell's Avatar
That will tell you when the piston is at the top of its travel, but it won't tell you if it's on the compression stroke or the exhaust stroke.
fourthaxis
Jan 5, 2013 06:57 PM
honda fan forever
Classic Hondas
Sep 12, 2008 08:17 PM
obuhmyuh
10
Feb 5, 2008 12:41 PM
T--Rex
Oct 21, 2004 05:49 PM
dpo95si
Aug 17, 2002 08:11 AM
