Need Torque spec on 96 accord
Old Oct 8, 2011 | 10:40 PM
7azhar7's Avatar
Default Need Torque spec on 96 accord
Need torque spec for the lower spark plug o-ring. For the 12mm and the 10mm. heard it was 16lbft for the 12mm and 9lbft for the 10mm. is that right for 96 accord. lx 4 cyl non-vtec f22b
Old Oct 9, 2011 | 04:05 AM
GhostAccord's Avatar
Default Re: Need Torque spec on 96 accord
You heard correctly!
6 x 1.0mm = 9 lbf-ft (10mm)
8 x 1.25mm = 16 lbf-ft (12mm)
Make sure that you loosen all of the valve clearance adjusting screws before you start torquing the rocker assembly down. This will keep anything from getting bound up and possibly bending or causing a false tq reading.
Old Oct 9, 2011 | 01:08 PM
7azhar7's Avatar
Thank You
Old Oct 9, 2011 | 06:41 PM
Your welcome
Wrens
Jun 10, 2015 11:48 AM
toker2
Mar 11, 2014 10:08 PM
mothornton
Sep 8, 2011 02:45 PM
01celica_gts
Sep 17, 2006 01:12 PM
