d16z6 confusion soo many issues
ok so i just bought a 93 civic si with stock motor d16z6 all stock everything
so my car smokes on start up bt not at regular driving speed or wot
my car feels like it lags at low rpm until like 2500 rpm
compression tested: around 200 all across plus or minus 5 psi
i read your supposed to test at wot so i got that reading of 200 but without aot i got a mix of 150 100 180 100
just put brand new spark plugs in and in less than a week they are already black with residue on them
smells like running rich but i passed smog but used 2 cats * edited
im sorry for the bad post still new to the site
please help
thanks in advance
please help
thanks in advance
What color is the exhaust smoke at start up? Sounds like the engine is running rich.
Any CEL codes? Have you done a tune up (plugs, wires, cap, rotor, ignition timing)?
With numbers like those, you can either have a blown headgasket or non existent rings...like marc said, the engine is probably done. Again, correct me if I`m wrong, but you have two options to fix it, pay about $1500-2000 or more to get it fixed, unless u can replace piston rings and head gaskets yourself. Or, swap the motor for a better D16Z6 if you want the same motor, or swap it.....But I could be way off if you did the compression test wrong
no cel codes and timing is dead on with new distributor smoke is hard to tell but its white n i correct myself it doesnt smell like its burning oil smells like fuel
If you tested compression at WOT with a fully warmed up engine, then compression is fine.
Check the exhaust smoke again:
White smoke = coolant
Blue smoke = oil
Black smoke = fuel
Blue smoke = oil
Black smoke = fuel
add a cap full of oil to each cylinder and redo ur compression test. the oil will help seal the rings and if u get higher readings then ur rings are shot.
typicaly
rings = blue smoke at high rpms
valve guide seals = blue smoke at start up after sitting for several hours
If it's on start up then it could be your valve seals. Also, you should check your cap/rotor, spark plugs, ignition timing, spark plug wires and make sure your battery is properly grounded since you said it lags at low rpm. What color smoke is it OP?
the truth of it is you have a d16z6 with x number of miles on it in a 17 year old car. If it is only doing it at start up and such a small amount that you cant really tell dont worry about it. Give the car a tune up cap, rotor, plugs check the ign timing and drive it. My 93 si has 230k plus on the original engine did compression test at 215k when changing the head gasket for the second time had 185 across the boards and it use almost a 2qrts of oil every 3k (bad valve seals). Keep the oil full and drive the **** out of it until you have the cash to replace it. The d16z6 only had 125hp in stock form so power is minimal to begin with. So many people on these boards think their car is going to blow up because it uses a 1qrt every x number of miles the truth is if you keep the oil topped up and drive it you shouldnt have a problem. Its when you dont check the oil and its low 3qrts that bad things happen fast.
