Easiest Method for drilling ss304 for 02 bung?
Old Oct 8, 2011 | 06:45 PM
arc_55's Avatar
Default Easiest Method for drilling ss304 for 02 bung?
Recently i have been thinking there has to be some easier methods for drilling ss304 material for 02 sensor bungs. I generally do not want to work harden the material so i try and keep the piece cool and drill at low speed.
My current method is a drill press using a stepped drill bit.
I am curious to know your methods and if you have any specific tools or bits that might make the job easier?
Old Oct 8, 2011 | 11:14 PM
k24em2's Avatar
Default Re: Easiest Method for drilling ss304 for 02 bung?
Try using some Castrol Moly Dee fluid...It works wonders on tough stuff like stainless. Those step bits work pretty well if you have the cobalt version of it. Make sure your cutting edge is SHARP.
Old Oct 9, 2011 | 04:48 AM
weiRtech's Avatar
OG Fabricator
just use the proper size drill alan. the step drill takes too long to get the proper size which creates more heat. also use some coolant if you aren't already. or you could plasma the hole, but that might require more tidy up before welding the bung.
Old Oct 9, 2011 | 07:10 AM
9bells's Avatar
OG Fabricator
I use a hole saw. Fastest with least heat. I use the good Morse red ones. Last forever.
Old Oct 9, 2011 | 07:26 AM
Lugzilla's Avatar
Canuckian
Use lots of coolant or if you can get some jokish that stuff is great. Use a 1/8th bit to start it off, step it up to about half your actual size then the third bit is your actual size. Keep your speed around 350-400rpm for the 1/8th, step it down accordingly for the next bit. Make sure your bits are sharp otherwise you may be there for a while.
Old Oct 9, 2011 | 07:28 AM
PTPbracket's Avatar
I use a rotabroach, they are super tough and real precise.
Old Oct 9, 2011 | 10:51 AM
k24em2's Avatar
Those annular cutters are fantastic
Old Oct 9, 2011 | 11:08 AM
PTPbracket's Avatar
yeah, they make it so easy.
Old Oct 9, 2011 | 12:47 PM
SpeedwayCoating's Avatar
Most of the time I use a sharp stepbit and drill press. But I am sure there are better ways.
Old Oct 9, 2011 | 07:14 PM
ToxicFabrication's Avatar
OG Fabricator
Same, also use a few different sized hole saws with carbide teeth. So far I have yet to see one fail.
Old Oct 9, 2011 | 10:30 PM
Boosted_B_Series's Avatar
Hole saws work great on the thick sch10/40 304
But if its in a down pipe, just blow a hole in it with the tig torch..
Old Oct 11, 2011 | 02:25 PM
mikesrex's Avatar
this is what I do
a267mm
Welding / Fabrication
14
Nov 21, 2013 04:19 AM
85
Feb 8, 2010 08:21 PM
will7
Jan 10, 2006 07:54 PM
Ca$h
Jan 13, 2005 02:22 PM
ciRcuitJerk
Mar 14, 2003 12:53 PM
