ls build - Is my woodruff key too small?
Old Oct 8, 2011 | 05:56 PM
honda_boy23's Avatar
Default ls build - Is my woodruff key too small?
ok so ive got an Ls out of a 98 teg. and it seems the closer i get to putting it in my ek the more little speed bumps i seem to hit. so the latest problem is with the crankshaft timing belt gear. the woodruff key i have seems like it isnt long enough to hold the time belt gear and the crank shaft pulley. the one i got from the dealership just seems to small. is it just suppose to hold the gear or is it suppose to hold the gear and crank pulley??
Old Oct 8, 2011 | 07:03 PM
98civdx's Avatar
Master Detailer
Default Re: problems with my ls build
The woodruff key is really small.
All it does it slide into the gap on the pulley/gear and sit there. It stops your from spinning the pulley without out the crank.
Old Oct 8, 2011 | 07:10 PM
so it just sits in the gap between the two?
Old Oct 8, 2011 | 07:38 PM
98civdx's Avatar
Master Detailer
yep. The little slit in the pulley/gear will line up, and it just hangs out in there.
Old Oct 9, 2011 | 05:59 AM
Former User's Avatar
Default Re: ls build - Is my woodruff key too small?
Please place simple tech questions directly into the thread title - edited.
Old Oct 9, 2011 | 08:40 AM
Thx man.
My bad ronj, ill remember that nxt time
misterpsycho
Oct 28, 2008 05:23 PM
Themouse
Feb 3, 2008 08:29 PM
downeyballz
May 15, 2007 03:16 PM
H22AJSPEC
Jul 16, 2003 07:38 PM
VisualEcstasy
Apr 22, 2003 02:44 PM
