Brake hoses/lines Questions about fitting sizes
Old Oct 8, 2011 | 05:41 PM
Antinull's Avatar
Default Brake hoses/lines Questions about fitting sizes
Hello,
I have a 1990 crx dx i am putting A d16a6 in and i am currently trying to setup the brake system
I am using brake hoses rather than hard lines, the hoses will go from the prop valve (mounted in the passenger compartment) all the way to the brake calipers / drums
I need to know what size fittings the calipers and drums use on these cars (can't seem to find it in the manual)
it looks like i need a 10mm banjo for the front (but i can't confirm this)
and i am not sure what the rear uses
(i don't have all of the parts mind you)
Old Oct 9, 2011 | 10:01 AM
Antinull's Avatar
Default Re: Brake hoses/lines Questions about fitting sizes
looks like the rears use a 10x1 standard fitting and the fronts use a 10mm banjo
i got this information from a manufacturer of crx braided hoses :D
off to buy adapters
also, it looks like i can't use the soft lines all the way into the rear drums
i am getting some female adapters and using the original rear hard lines
dacrxguy
Jul 24, 2009 09:58 PM
chris3385
Mar 25, 2009 11:21 PM
JDM_SOHC
Jul 16, 2007 05:38 PM
Reelizmpro
Jul 12, 2007 05:05 PM
pumafeet10
Aug 19, 2004 05:24 PM
