DISTRIBUTOR
Old Oct 8, 2011 | 04:45 PM
William1991b's Avatar
Default DISTRIBUTOR
i got my car checked and said need new distributor cap and rotor.
1 How hard is it to change?
2 Do i need to put a new o-ring when i change it? heard you do but idk
Old Oct 9, 2011 | 04:19 AM
GhostAccord's Avatar
Default Re: DISTRIBUTOR
When you buy the cap and rotor they usually come with a new o-ring/cap seal. It's a fairly easy job to do. there are 3 screws on the cap and one on the rotor. The Philips screw on the rotor shaft may require you to turn the engine over a bit to get the screw lined up with the opening in the dust cover. you can ether do this with the ignition or manually rotating the crank.
Make sure that when you remove the spark plug wires from the cap that you do it one at a time and put them in the same spot on the new distributor. Or at least document what one goes where.
Old Oct 9, 2011 | 07:44 PM
nus_dogg's Avatar
What GhostAccord said.
yangkm
Feb 26, 2011 04:20 PM
paniaguae640
Nov 27, 2007 03:57 PM
Japanese1.6
Apr 10, 2005 08:42 AM
thaimonkee
Jul 8, 2003 07:28 AM
GRM Scott
Mar 1, 2002 04:41 PM
