Alternator out after 263,000
Old Oct 8, 2011 | 02:12 PM
ttmix's Avatar
Default Alternator out after 263,000
Man! This is car week for me. My original alternator is a Denso 12V/80amp, I've seen a few online that say 14.2 amps/90+ volts. Will it hurt my car to put one of those on or should I stay with the original Denso TN101211 type?
Thanks
Old Oct 8, 2011 | 02:26 PM
redbull-1's Avatar
Default Re: Alternator out after 263,000
90 + volts!!!???
If the alternator is a Denso, is your car a 4 cylinder? If so, you may be able to just replace the brush pack and go even longer. The Denso alternators for the 1999 Accord 4 cylinders should use the same brush pack as the 1990-1997 Accord, Honda part number 31105-PR7-A01. Also see this thread:
https://honda-tech.com/forums/honda-accord-1990-2002-2/any-one-ever-replace-alternator-brush-90-accord-lx-2889481/
The attached alternator diagram is the Denso alternator for a 1999 Accord 4 cylinder.
Most V6 came originally with Delphi alternators ( which most where crap).
Old Oct 8, 2011 | 03:06 PM
ttmix's Avatar
Yes, mine is a 4 cylinder. I'll check out the brush pack. If I choose to replace can I install a 14volt 90+amp?
Thanks
aamccarty
Feb 22, 2017 08:01 AM
nanodc2
Nov 21, 2014 11:01 PM
PineiroDante
Dec 7, 2011 09:06 AM
stRodda
Jan 3, 2005 12:42 PM
